Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 04-02-2010, 04:25 PM   #1
92civeg
92civeg's Avatar
Send a message via ICQ to 92civeg Send a message via AIM to 92civeg
Default 08 civic stuck in 5th gear
car: 08 civic 5 speed manual
miles:20xxx
Car was stuck in 5th gear, i disconnected the shift linkage at the trans and manually shifted the gear selectors no problem, i hooked the linkage back up and it was free (shifting perfectly). I drove it in the city for 5 min without a problem, then i got on the highway and drove 2 miles and it was stuck in 5th again.
brought it back home and ordered new shift cables (linkage cables) i replaced them took it back down the highway and wouldnt you know it its stuck in 5th again fml.
when it does stick in gear it doesnt matter how i rev/depress the clutch it does not want to come out, if its internal and i crack the case open will it be noticeable?
got any suggestions?
92civeg is offline   Reply With Quote
Old 04-02-2010, 05:33 PM   #2
BryanM.
Resident Gearhead
2007 Honda Civic
BryanM.'s Avatar
iTrader Rating: (1)
Default Re: 08 civic stuck in 5th gear
Still under warranty?
PICS: '07 FG1 - DD
......... '96 EJ6 - SOLD
......... '92 EH2 - SOLD
BryanM. is offline   Reply With Quote
Old 04-03-2010, 03:37 AM   #3
92civeg
92civeg's Avatar
i try to keep other peoples hands out from under my hood
Old 04-03-2010, 09:14 AM   #4
fcm
Old Fart
fcm's Avatar
If you can shift it out of 5th by hand once shift linkage is disconnected it would indicate it is not internal, although still possible.
Questions...
Have you checked the tranny fluid/oil level?
When it is working is the shifter loose/sloppy?
If so, replace bushings at both the tranny and shifter end of linkage.94
RIP Zack 2001-2013, my best friend.
fcm is offline   Reply With Quote
Old 04-03-2010, 01:35 PM   #5
92civeg
92civeg's Avatar
I drained the fluid into a funnel filter and it was clean( no metal debris)
and refilled it with honda mtf..... no the shifter isnt sloppy at all.
Questions...
Old 04-04-2010, 07:44 AM   #6
fcm
Old Fart
fcm's Avatar
I don't know what to tell you, because you can shift it out of gear by hand when linkage is disconnected would indicate it is not an internal problem and must be in the shifter, linkage or connections.
You said you replaced the linkage and the shifter is not lose or sloppy, that would indicate it can't be a linkage problem, so back to an internal problem.
Questions...
Has the car been in an accident, [possibly a bent chassis]?
When you shift it out of gear by hand, [once linkage is disconnected] is the engine running.
If not, do you still have to depress the clutch to get it out of 5th?
You said when driving it will not come out of gear no matter what, does that mean either when accelerating or when decelerating and at any speeds? 94
Old 04-05-2010, 06:07 AM   #7
92civeg
92civeg's Avatar
no accidents, i guess im going to have to crack open the case, in order to crack the case
5th, 94, accord, car, civic, doesnt, gear, honda, manual, problem, shift, stick, sticking, stuck, transmission
