OBD Code P0301 and P1399 – Need help
Old 03-31-2010, 12:48 PM
billbuhrman's Avatar
Icon2 OBD Code P0301 and P1399 – Need help
My 97 Honda Accord is giving Code P0301 and Code 1399. In addition to this at idle the CEL blinks. This goes away on a flat road, no load, however when loaded, up hill for example, the light blinks. I have checked the plugs, the wires, the distributor, and the rotor, all look to be OK. Any thoughts on a direction to go?
Old 03-31-2010, 01:09 PM
GhostAccord's Avatar
Default Re: OBD Code P0301 and P1399 – Need help
A flashing CEL while driving is a misfire indication. DTCode P0301 is an OBD2 Cyl #1 Misfire code.
A misfire can be caused by ether an ignition or fuel issue. If you have checked all of the ignition parts and tested them to be in operating ranges. You could begin testing the fuel supply system. It could be a week fuel pump or inoperative fuel pressure regulator or a faulty fuel injector. I would start with testing injector No.1.
Old 03-31-2010, 01:25 PM
I can remove the injector, as I have done it before. Is there an easy way to tell if it’s bad or clogged?
Old 03-31-2010, 01:53 PM
With the engine running you could place a long metal/wooden rod (screw driver) and touch one end on the body of the injector and your ear to the other. You should hear sharp clicks, make sure they all sound the same if one doesn't sound like the others that would be an issue. That's one of the easy ways to check for operation. The other is, with the engine off, check the resistance between the two pins of each injector. It should read 2.5-3.5Ω, anything other than that and they should be replaced.
As for testing flow of the injector. That is something that has to be done with the injectors out of the car on a test rig.
Old 03-31-2010, 03:44 PM
When I remove the connector to the supect injector the idle speed does not change. However the ohm value checks out. Think I should replace it?
Old 04-05-2010, 06:57 AM
lordnight's Avatar
i think first u should focus on miss fire cyl #1 swap plug n wire to difference cyl.. and run see if the miss still in cyl #1
Old 04-05-2010, 01:22 PM
Thanks all. Changed Plugs, Wires, Rotor, and Cap and the problem went away. Not sure which fixed the problem, however and the car has over 200,000 miles on it these things needed to be done. Any way thanks as the problem is fixed.
Old 08-04-2010, 09:45 PM
kwahamot's Avatar
I'm having the same problem with my 2000 Accord EX SULEV. It was running fine at 7 p.m., then at 8 p.m. when I left work to go home it started up and ran very rough then the cel came on and I got the codes p301 and p1399. A mechanic told me a couple of weeks ago that I need to clean the throttle body. Is there any online resource for the procedure? I don't have a Haynes manual for the Accord.
Old 08-04-2010, 10:21 PM
phootbag's Avatar
Never seen a dirty throttle body cause a misfire.
Old 08-05-2010, 12:00 AM
kwahamot's Avatar
Maybe it's the fuel injectors or spark plug wires. I had a Ford Escort GT whose spark plug wires suddenly went bad and the same beahvor insued. I thought it was bad petrol.
Old 08-05-2010, 05:07 AM
PTV6's Avatar
Have you got an i4 or a v6?
Old 08-05-2010, 08:29 AM
kwahamot's Avatar
It's a 4 cylinder. 4 speed automatic. I recently replaced the prmary O2 sensor and had a transmission rebuild. Spark plugs are a few months old and guaranteed for 100,000 miles.
Old 08-05-2010, 09:58 AM
PTV6's Avatar
Had you changed your rotor, cap and wires while swapping the plugs?
Old 08-05-2010, 10:14 AM
kwahamot's Avatar
No, but I thought they had been changed when I had the 105,000 mile maintenance a couple years ago. It cost $1200.00 so I'll have to check the receipt. Anyway, I'll look at the cap and rotor first. It's at 145,000 miles now. I had a wire go bad suddenly on an Escort GT used to own, so that can happen. One second it was fine, the next second...poof!
Old 08-05-2010, 04:56 PM
kwahamot's Avatar
Changed spark plug wires, cap, and rotor and still getting the misfires at low rpm. In fact, it seems worse now. I looked at each spark plug and they are fine.
Old 08-06-2010, 04:04 PM
kwahamot's Avatar
I replaced the coil today based on a local mechanic's diagnosis (low resistance on the primary circuit) and still no improvement. He also tested it by removing one spark plug wire at a time and noticed that the misfiring didn't really change much with any of the spark plug wires removed, so it's sort of a general misfiring. What other components could cause this? As I said before I've replaced the cap, rotor, wires, and plugs. I'm thinking it could be the ICM or mass airflow sensor.
Old 08-06-2010, 04:05 PM
kwahamot's Avatar
I'm getting codes 300, 301, 304, and 1399.
Old 08-06-2010, 08:36 PM
phootbag's Avatar
Valve adjustment?
Old 08-06-2010, 08:55 PM
Accordin2me's Avatar
try the crank sensor, kall me krazy but sounds lyke a ckp 3 me...
Old 08-07-2010, 12:04 AM
kwahamot's Avatar
I'm thinking it's the ICM.
Old 08-07-2010, 07:15 AM
jhondayang's Avatar
Originally Posted by phootbag
Valve adjustment?
X's 2.
The crank sensor will not cause a misfire code. If it is bad, your car won't even start.
Old 08-07-2010, 06:43 PM
kwahamot's Avatar
I replaced the ICM and the Map Sensor...still misfires like crazy!
Old 08-07-2010, 08:36 PM
kwahamot's Avatar
I don't think it's the valves. It started running bad suddenly. Plus if it was the valves it seems like higher rpm would still be a problem, but it runs very smooth at higher rpm.
Old 08-08-2010, 05:34 AM
poorman212's Avatar
Have you checked the timing, when was the t-belt last changed.
Old 08-09-2010, 04:51 PM
kwahamot's Avatar
T-belt and timing are fine. Looks like it's the intake manifold. Blown gasket. I hope that's the end of it.
Quick Reply: OBD Code P0301 and P1399 – Need help
