| Welcome to Honda-Tech! | ||
#1 |
hi i was wondering whats the max power made on a standard cp piston wrist pin.
im building a fully built h22 but i forgot to upgrade the wrist pin. i would hate for that to be my down fall on my build. if this question is in the wrong location i apologize.
H2B Stock 198 HP 157 TQ H2B boosted in the works. 09 is mine... ok maybe 2010... |
#2 |
Nobody is going to have an answer that's worth a damn. Your best bet would be to call CP and ask what they're designed to handle.
92 Civic CX - Turbo H22A, 700+whp @ 29psi 10.42@144mph (148mph) Good folks: Joe Simpson@Tempest Racing, Jeremy Allen@InlinePro |
#3 |
a close friend of mine made 700whp on off the shelf CP pistons
K-Serious! 990whp 600tq billet 6766 9.2@164 10.67@134 DD 2600lbs http://www.speedfactoryracing.net/ for all your go fast needs |
#4 |
when I called CP and asked them they said between 5 and 600, but there are people on this forum making 1000ish on stock wrist pins...I personally have the upgraded ones just for peace of mind.
Round 2 build |
#5 |
thanks guys.
my budget is on its final string so i think im just gonna run the standard wrist pin and get the car dialed in. then upgrade when my money back to par. gonna enjoy what i have for now. thanks again.
#6 |
for those who have upgraded pins (primarily CP), did you have to hone out the small end of the rod and/or wristpin opening in the piston to add clearance? or did you just run the upgrade .180 wall pin in the standard piston and rod? Thanks!
Lou
FS: OEM Civic 1992-1995 EG/EJ Coupe/Hatchback door skins. Brand new in the box from Honda. PM me! |
#7 |
1994 Acura Integra |
On all of our engines, we have them Pin fit at the machine shop. Wiesco/JE/CP all of em. You'd be surprised how off some of them are.
710whp@30psi 6262 E98 New setup 10.12@151mph, 11.57@137.48 Street tires Englishracing.NET|Extreme Turbo Systems| GSC |
#8 |
Its usually just a thicker wall pin same outer diameter, inner diameter is smaller and the material is of course stronger. Why not just upgrade pins, its like 75 bucks more to upgrade wrist pins. I ran my standard pins to 650+whp without problems but im not chancing it with the new power goals of 800+, not much money for peace of mind.
1992 Nissan Sentra SE-R (B13) SR20VE-T, CP 9:1 pistons, Manley Turbo Tuff I-beam rods, ACL race bearings, Mazworx 1/2" headstuds, Mazworx PE headgasket, BMC race intake manifold, ID2000's, Weldon Fuel pump, Precision T4 6765, and much more. |
#9 |
yea you always need rods hone at machine shop...they come tight....
#10 |
Thanks guys. I was told by some popular vendors on here to just slide them in and run them without pin fitting. Anyone have a spec of what kind of clearance they should have? I'm running CP Pistons with their 9210 upgraded pins. Same outer diameter etc, just a slightly smaller hole in the middle. Thanks.
Lou
#11 |
My h2b made last year on 9.1 comp cp piston with stock wrist pin that they came with 831hp at 33psi never had any problem with it I will said that u will have to worry when u start making over 900hp plus just my opinion
Zakura h2b tune on s300 9.1@165mph 60s1.6 129mph in the 1/8 mile kinetic motorworks.com ,Dosky fab,!Zflow! |
#12 |
i'd just save up the extra 150 and get the upgraded wrist pins
It's just a little piece of mind
VOUCHES: ruehl925..bokals..AZSTATEPOLICE..johnny G..MildWater..sgriffiths..nytosc..gizzmo555..clovi skilla..IlluSiv3 2013 (fingers crossed) sfwd race car!!!!!!!!!!!!!!!!!!!!!!!!!! |
#13 |
Hey, I think I know that guy your talking about... Oh wait, that guy was me haha!
I made 700/500 on stock wrist pins revving to 10200-10400 and beat the living hell out of the car, never had any problems. Wrist pins and pistons themselves looked great after 5k miles. Spun a bearing so got a chance to check them!
92civic si~688/488@29psi 84mm gsr t3/t67ho!!! PARTED OUT 10.44@139.98@20psi 1.65 60ft! www.speedfactoryracing.net |
#14 |
The wrist pins will outlast the off-the-shelf CP pistons at that RPM and power level. You'll eventually finds cracks at the base of the skirt. The non-strut design just can't deal with the abuse. The off-the-shelf pistons will last about a full season though... but when you're ready for a piston that really can deal with the abuse, we have these:
![]() The underside looks like this... it's just an iphone pic but if you look closely you'll see the cracks in the corners of the skirt. Our HD piston has a strutted skirt to keep the skirt from flexing, cracking and collapsing.
***8.47@176 mph*** The fastest H22 powered car in the world Check us out at www.KStuned.com |
#15 |
Those are some strong looking pistons Reid!
JJsmotorsports.net/Used b-series oem parts in stock!2004.5 Dodge Dually My Tow Horse 1995 Vx Hatch SFWD,Millertime Fuckin'em/T1/PTE/Dss/Noribilt/Motec/ FTWFuel/Golden Eagle 9.08@173.9.......IFO's FTW!!Best 60ft.1.46! On M&h tire 24.5 sfwd |
#16 |
1999 Honda Civic |
doesnt really make sense to me why they wouldn't manufacture the shelf version like that. People will still destroy it, but from melting rather than collapse.
www.MSSRACING.com - 9.84@160 - Main Stream Performance / Competition Clutch / Arias Pistons / Mahle-Clevite Bearings / JKOBD.com / TDC Performance www.IMPORTSHOWDOWN.com |
#17 |
Those pistons look sick. Much beefier.
For those who are wondering about pin fitting, I am sending my pistons, rods, and upgraded CP pins to my machine shop today. I'll let you know the results. I am thinking no change will be necessary as the upgraded pins slide smoothly (if not even looser) into the piston and through the rod than the shelf pins do. Lou
#18 | |
#19 | |
Lou
#20 | |
Boostedeg6-1 is a scammer. Do not buy anything from him. |
#21 |
dude the upgraded wrist pins for 1000hp+ from ipgparts.com are only $99.
2011 True Street build in progress [Evans Tuning][BlueRidge Motorsport]][ipg parts] |
#22 |
you DO NOT!!!! need to machine anything to run upgraded Wrist pins. the inside diameter of the upgraded pin is smaller therefore a thicker side wall, outer diameter remains the same as the standard pin. as stated earlier... I can associate it like this say you are running 24.5 slicks on 15" rims, an uprgade would be to run 24.5" slicks on 13" rims would give you bigger side walls without increasing the diameter of the tires. hope this helps.
bigboostmotorsports: www.bigboostmotorsports.blogspot.com. www.Importparts.com. www.DP-engineering.nl |
#23 |
I went 760ish whp(dynojet) at 30psi for about 20-25 hits(including track+street passes). Then we we went 33 psi at the track once it ripped the wristpin right our of the piston and kabaaaam'd everything. It was CP's 11.5:1 shelf piston.......that was a bad idea.
Pro Function http://www.profunctionauto.com http://www.ProFunction.FreeForums.org |
#24 |
This is why I'm running diamonds this year.
Dynotuned l Bailey Motorsports l Boss&Sons LLC l Synchrotech-transmissions 9.725@154 www.facebook.com/BryanBuiltTransmissions |
| Tags |
| cp, h22, honda, hondatech, pin, pins, piston, pistons, s2000, stock, tech, upgraded, vs, wrist, wristpin |
