Old 03-28-2010, 07:24 PM   #1
boostjunkieee
boostjunkieee's Avatar
Send a message via AIM to boostjunkieee
Default Temp gauge runs hot but car makes no heat...... HELP
I have a stock 97 Civic DX coupe. A few days ago while driving I noticed the temp gauge was running hot, sometimes real hot, i turned on the heat to try and get it to go down but all it was blowing was cold air. I figured my theromstat was going bad so I replaced that and it did nothing. So then I spent 7 ****ing hours tearing the dash out to replace the heater core and that also did nothing to fix the problem, it made it worse. Im stumped on what it could be, maybe a clogged radiator?? Any help would be awesome, im losing my patience fast and I have a real big hammer close by.
95 Civic - SOHC Turbo
*373whp 315ft/lbs*
boostjunkieee is offline   Reply With Quote
Old 03-28-2010, 07:29 PM   #2
boostjunkieee
Default Re: Temp gauge runs hot but car makes no heat...... HELP
Stock Y7 and no CEL's also.
*373whp 315ft/lbs*
Old 03-28-2010, 07:36 PM   #3
dmeconitas
dmeconitas's Avatar
the only time that happened to me was there was no coolant in the radiator. The heater gets it heat from the hot coolant. So either you have no coolant, or you have a clog somewhere.
dmeconitas is offline   Reply With Quote
Old 03-28-2010, 07:41 PM   #4
boostjunkieee
Its full of coolant. Im thinking a clog also. I might let it run for a while tommorow and check the hoses to see if any are cold. ran out of daylight today.
*373whp 315ft/lbs*
Old 03-28-2010, 07:42 PM   #5
shwanC
shwanC's Avatar
iTrader Rating: (3)
It could be the heater control valve for the heat (or clogged heater core lines). It is what the temp. slider is attached to. This is between the engine and the heater core (under the hood). This might be the problem for no heat, but does not answer why the car is overheating. It could have been low on coolant, and boiling out. This could be caused by a faulty rad. cap, not keeping the pressure up. Also, since you changed the thermostat, make sure the coolant is bled properly, open the reliefe valve (somewhere around the thermostat) and run the car till the rad. fan turns on. Coolant will pour out, close it when there is no more bubbles coming out. If the car overheats while sitting, it could be a faulty fan switch.
Quickest and cheapest way first, change the cap and re-bleed the coolant system.
shwanC is offline   Reply With Quote
Old 03-28-2010, 07:42 PM   #6
dmeconitas
dmeconitas's Avatar
this isnt environmental friendly, but you could put a hose in the radiator and remove hoses and see if water is coming out. You need to remove the t-stat though.
Old 03-28-2010, 07:43 PM   #7
92lxsleeper
1992 Honda Civic
92lxsleeper's Avatar
well if the temp gauge is reading hot then there is coolant in the system. cause if there was a leak, and it was empty and overheating, the coolant guage would probably read normal since there is no coolant to heat up the temp sender.
My name is Lauren <3 I'm 24.
Real Girls Fix Their Own Cars
My youtube -----> http://www.youtube.com/user/automotiveDIY
92lxsleeper is offline   Reply With Quote
Old 03-28-2010, 07:49 PM   #8
boostjunkieee
Temp slider seems to be working fine, checked it thoroughly on both ends. I'll take out the heater control valve tommorow as well to make sure its not clogged. Rad cap is new. Going to bleed the system tommorow also. Hopefully it works. Ill keep it updated.
*373whp 315ft/lbs*
Old 04-14-2010, 12:26 PM   #9
boostjunkieee
The problem was the brand new thermostat was bad. I popped it out the next day and let it idle to to see if any hoses were cold, they were all warm so i knew it was bad. All this work for a $17 piece of **** defective thermostat.
*373whp 315ft/lbs*
2000, 95, car, civic, fine, gauge, guage, heat, high, honda, hot, needle, odyssey, overheating, reads, shows, temp, temperature
