Old 10-09-2012, 08:29 PM
  #2501
SHG_EasyE's Avatar
Default Re: SHG is back! Easy's EP3 goes under the knife...
Finally have a chance to update with the rest of the install...
Heres a comparison between the original springs and the ERS springs I switched to. Buddy Club uses 8" springs, but this adds extra weight and leaves much less room for ride height adjustment. Since I was switching rates anyway i went with a 6" spring. You can see how much extra room there is in the picture. Both struts are adjusted to the same overall length...
One of the only drawbacks of these coilovers was that the schrader valves for the nitrogen were not a standard thread or length, so I couldnt install the charge tool on them. I had to re-thread them, then file down the base so the tool could thread on all the way to make a seal...
Once that was done I got the canisters charged with nitrogen, set at 175 psi
Here they are installed with the new strut bar! I used some heat barrier foil around the canisters to help prevent heat soak. Notice the sweet intake lol. Unfortunately the airbox doesnt clear the canisters and i really have no other mounting option for them, so this is a temporary fix until I figure out a new intake setup!
Threw some gold foil on the brake lines where they come close to the rotor and caliper too. Ive seen the teflon coating on the lines become brittle on other cars from exposure to high heat
And here are some pics from the alignment tonight. No corner weight for now since I had another car on the scales at the time.
Old 10-09-2012, 08:33 PM
  #2502
mattrt09's Avatar
Originally Posted by SHG_EasyE
The scope for my project is to have race car rigidity, engineering and performance under a street car skin (oem sheetmetal and full interior) much like the OPERA DC5
it seems this is the new direction that most people are aiming for with their cars these days.
new update is very nice, are those canisters too much in the way of the VC? seems like a lot to take off to get access to the coils or to take off the VC, did you take off the top of the airbox to allow for more room?
and i might steal your idea on my brake lines for my install...
  #2503
Loganej8's Avatar
damn duude
Old 10-09-2012, 08:35 PM
  #2504
BlackNDecker's Avatar
Any plan to upgrade the intake manifold? My engine bay is as tight as yours and the RSP intake manifold fit with just slight massaging of the rad support, It appears to match the RRC on stock compression k24s....still unknown how they compare on built long blocks and ported heads.
Awesome updates BTW...
Old 10-09-2012, 08:52 PM
  #2505
SHG_EasyE's Avatar
Yeah they will make for extra work in the future, but its just 2 alans for the canisters, and 4 nuts for the bar. Extra 5 min to get to the coils or VC. I havent had to take either off since Ive owned the car other than to paint it lol.
Im putting in a K20A2 next spring with an RBC, so Ill have to do some modification to the rad support and figure out where to mount the hood prop stay.
Old 10-09-2012, 09:11 PM
  #2506
...and figure out where to mount the hood prop stay.
I want to find a set of aftermarket hood hinges for cf hoods that don't require a hood prop. There is a company that makes these but I can't recall the name off hand (they always advertise in Honda Tuning).
I've been browsing through your blog for the past hr. Greeeeeeat pics
Old 10-10-2012, 07:23 AM
  #2507
Skunk2ner's Avatar
Wow... Just wow...
Old 10-10-2012, 07:47 AM
  #2508
gabebauman's Avatar
Awe yeah boi.
Old 10-10-2012, 09:06 AM
  #2509
SHG_EasyE's Avatar
Yeah, Im considering one of the pistons for one side.... But if I can make the oem prop work Ill keep that.
Old 10-10-2012, 01:32 PM
  #2510
00siboy's Avatar
Nice . Stayin SHG consistent.
Old 10-10-2012, 01:41 PM
  #2511
Spongebrad Squarepants
Egezzy's Avatar
Those remote canister "brackets" are spot on! Well done.
Old 10-11-2012, 06:25 AM
  #2512
SHG_Claudio's Avatar
Thanks, I've been keeping it in check
Old 10-12-2012, 11:47 AM
  #2513
circa86's Avatar
Can you move to the bay area or clone yourself and put him in the bay area and have EasyE clone work on my S2000?
Great update!
Old 10-14-2012, 12:29 PM
  #2514
Paul 631's Avatar
Amazing work as usual Evan!
Just curious, do you add extra oil prior to track events, or stick w/ the regular 5-qts; & what grade?
Old 10-14-2012, 03:34 PM
  #2515
willimo's Avatar
Holy moley. Beautiful work, those brackets are awesome. I am in awe of your work and abilities and how much thought you put into everything... rebuilding your shocks is nuts! This is an AMAZING car.
Old 10-15-2012, 03:45 AM
  #2516
Lazybean's Avatar
sick update as per usual!
Old 10-15-2012, 04:04 AM
  #2517
SHG_EasyE's Avatar
Great update!
Haha, honestly wouldnt mind finding myself living in SF at some point in my life
Yeah I overfilled it about 1/2 quart. I dont run an oil pressure gauge so I dont know what pressure was but the light never came on. I would baffle the A3 but since Im going to put the new motor in for next season I dont want to bother.. I use Castrol Syntec (Edge) 5w30
Thanks man! Its been a steep learning curve but it feels good to have everything in the car now and working perfectly!
Old 10-15-2012, 08:39 AM
  #2518
EP3Moschini's Avatar
Looks dope E!
Old 10-16-2012, 03:15 AM
  #2519
SHG_James's Avatar
What baffle are you planning to use? I'm looking to get the Clockwise Motion oil pan baffle & TTS timing chain baffle. I like the trap door design and the fact it doesn't need to be welded in.
Clockwise: http://www.k20a.org/forum/showthread.php?t=104117
TTS: http://shop.tractuffstuff.com/TracTu...1.qscstrfrnt06
Old 10-16-2012, 04:26 AM
  #2520
SHG_EasyE's Avatar
Im doing the clockwise baffle (we already have one for the DC5) and my own timing chain baffle. No sense in paying for something I can easily make myself
Old 10-17-2012, 11:31 AM
  #2521
SHG_James's Avatar
Good to hear!
Old 10-17-2012, 05:15 PM
  #2522
BrownDx's Avatar
Love this project, it inspires me.
Old 10-23-2012, 09:41 PM
  #2523
KC-
KC-'s Avatar
Any updates? This is the most influential and motivational build threads I've ever come across.
Old 10-24-2012, 04:10 AM
  #2524
EG-Kaos's Avatar
beyond impressive. fit and finish is crazy nice. keep it up!
Old 10-24-2012, 05:57 AM
  #2525
deckster333's Avatar
Wow. This build is just awesome man
Quick Reply: SHG is back! Easy's EP3 goes under the knife...
