Old 03-22-2010, 12:59 PM   #1
Naz04ryan
Naz04ryan's Avatar
Icon6 Oil Pump Install ???
Anyone know how much it cost for a shop to install a new oil pump on an integra, I know you gotta take off the timing belt and drop the oil pan. I am not attempting this heart surgery. Please i would love to hear a few estimates of how much im looking to fork out. I already ordered the new Type R oil pump. I just want to know how much a garage is gonna charge me for the install?????
Naz04ryan is offline   Reply With Quote
Old 03-22-2010, 01:49 PM   #2
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
Default Re: Oil Pump Install ???
Whats wrong with your oil pump? Not sure on the price but it wont be cheap.
Neptune RTP - HrTuning.com
www.Xenocron.com
95 GSR Partout http://hondamarketplace.com/showthread.php?t=3028136
mouab18c1 is offline   Reply With Quote
Old 03-22-2010, 02:43 PM   #3
Naz04ryan
Naz04ryan's Avatar
It is clogged i believe - read my thread and let me know what you think it is...
http://www.honda-tech.com/showthread.php?t=2746285
Old 03-22-2010, 03:23 PM   #4
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
So im assuming you switched out the sensor before buying a new oil pump correct? Is this a bone stock ls? I dont think the ITR oil pump will work with the stock ls. Someone correct me if im wrong. If I remember right only the waterpump was interchangeable.
www.Xenocron.com
Old 03-22-2010, 04:45 PM   #5
Naz04ryan
Naz04ryan's Avatar
Yes i replaced the oil pressure switch and Yes you can bolt a type r oil pump right up the a B18A, It is needed when you do LS-Vtec, It is bone stock block & Head, Ill already be a step ahead if i decide to go LS-Vtec. It will flow a lot better that the stock oil pump. More oil pressure is better than none. haha
Old 03-22-2010, 04:48 PM   #6
Naz04ryan
Naz04ryan's Avatar
Originally Posted by integra_101 View Post
If you ever need to replace your oil pump on your 96-up B-series engine, you might as well replace it with an USDM Integra Type-R unit. Integra Type-R oil pumps come complete with the front main seal. These oil pumps are perfect for LS/VTEC or B20/VTEC or any rebuild setups. The USDM Integra Type-R Oil Pump will bolt-up to any 96-up B-series motor. You can use these on 90-95 B-series engines as well, but will have to change the lower timing cover to a newer OBD2 (96-up) B-series lower timing cover, due to the provision on the oil pump for the crank angle sensor, found on all 96-up Honda engines
Old 03-22-2010, 11:53 PM   #7
AcuraLsSE
AcuraLsSE's Avatar
The ITR oil pump bolts right up to a 96-01 b18, anything before 96 requires you to buy a 96+ lower timing belt cover.
96 Acura Integra Special Edition 5 speed
HT mods bring the suck
AcuraLsSE is offline   Reply With Quote
Old 03-22-2010, 11:59 PM   #8
AcuraLsSE
AcuraLsSE's Avatar
I know a shop charges about 3 hours just to do the timing belt. Since you're going to have to take off the oil pan as well as the timing belt I bet you're looking at 4 hour min. Given shops at least in my area charge in between $85-120 an hour you going to shove out 4 bills or more.
Old 03-23-2010, 05:32 AM   #9
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
I would say $500-$600 and that's probably a deal. But really, it's NOT that hard to do yourself, although you really should spend about $100 on a GOOD torque wrench to avoid warping your oil pan.
Also, everyone pay attention to this: THERE IS NO SUCH THING AS A "TYPE R OIL PUMP" The OBD-II 96-01 Integra oil pumps were identical ACROSS the board for all VTEC and non-VTEC models, including the RS, LS, GS-R and Type R.
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
Old 03-23-2010, 08:50 AM   #10
seanbev24
seanbev24's Avatar
X2. If I was doing this to a b18a, I would use a 94-95 GSR oil pump, water pump, and timing belt. All these would be perfect for future LS/VTEC as well.
seanbev24 is offline   Reply With Quote
Old 03-23-2010, 09:41 AM   #11
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
Thats what I thought, thanks for the confirmation.
www.Xenocron.com
Old 03-23-2010, 09:45 AM   #12
integra_101
2006 Acura TL
My Garage
integra_101's Avatar
There is such thing as a type R oil pump. I worked at acura.
integra_101 is offline   Reply With Quote
Old 03-23-2010, 09:53 AM   #13
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
We are just saying they're interchangeable.
www.Xenocron.com
Old 03-23-2010, 10:52 AM   #14
seanbev24
seanbev24's Avatar
I just searched oemacuraparts.com for Type R, GSR, and LS. I used 1998 as an example.
All 3 list the oil pump as the exact same part number: 15100-P72-A01
Old 03-23-2010, 11:10 AM   #15
Naz04ryan
Naz04ryan's Avatar
Icon6 Re: Oil Pump Install ???
Hey guys, I appreciate all the feedback, Not tryin to start an argument over oil pumps. lol, but i got some feedback from my local honda performance shop and the owner told me to drop my oil pan and check for sludge since i let me car sit for a couple months with the VC off the head, Then replace the oil filter again and put fresh oil in. see how she runs and if its still getting clogged then im gonna replace the pump. Hopefully theres a lot of gunk in the pan and it just needs a good cleanse. too bad you can't just do an oil flush, just like a coolent flush. would prolly fix my entire problem... haha
Old 03-23-2010, 01:51 PM   #16
efvader
efvader's Avatar
you are wrong. 15100-p72-a01 serves all.
sometimes you gotta get low just to get through
efvader is offline   Reply With Quote
Old 03-23-2010, 04:47 PM   #17
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
lol nope. There is an OBD-II Integra oil pump, and an OBD-I oil pump for older Integras. That is all.
member #0001
Old 03-23-2010, 10:45 PM   #18
AcuraLsSE
AcuraLsSE's Avatar
I can't argue the part numbers being the same but I was told that the type r/GSR had a higher volume than the LS. I did read the article on team integra about them being the same and shimming the spring for more pressure but I thought the type r had higher volume.
Old 03-24-2010, 03:36 AM   #19
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
how could they be different if they all have the same part number? There's nothing else that distinguishes parts other than part number, that I know of.
member #0001
Old 03-24-2010, 06:59 AM   #20
seanbev24
seanbev24's Avatar
Magic jdm dust?
To the op, just get the 94-95 gsr stuff (obd1 pump is the same but you want the vtec t-belt/water pump), save money on a lower timing cover, and be done with it. Use the money you'd spend on labor for a helms manual and some quality tools.
Old 02-22-2013, 11:28 PM   #21
95dc2r_line
1995 Acura Integra
It's ok guy it's just a discussion, we should be thankful for having everyone's ideas, plus this forums for the discussion board and pages.
95dc2r_line is offline   Reply With Quote
acura, bolt, bseries, change, clog, cost, honda, hondatech, install, installing, integra, oil, price, pump, replacement, video
