Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 03-21-2010, 06:32 PM   #1
puertoricanboy90
puertoricanboy90's Avatar
Default LEAKING OIL FROM FILTER HOUSING!! HELP!!
so... my "new" Rex is leaking oil. Aside from pissing me off and being an inconvenience because I have to keep adding oil, the location of where the oil is coming from is horrendous. It is leaking from being the oil filter housing... now here is where the dilemma comes in to play. I have a third gen ZC DOHC motor. I know the D16A1 is very similar in design, so here comes my next questions. A: is this oil filter housing removable or integral with the block? B: would the D16A1 be similar enough in design that [if it is possible] I could buy and use the oil filter housing for that car?
Any, real, advice would be awesome. Thanks.
puertoricanboy90 is offline   Reply With Quote
Old 03-21-2010, 06:36 PM   #2
Jockone
Default Re: LEAKING OIL FROM FILTER HOUSING!! HELP!!
Do you mean the part with the oil cooler that the filter screws onto?
You might be a King or a little street sweeper but sooner or later you dance with the reaper.
Jockone is offline   Reply With Quote
Old 03-21-2010, 06:52 PM   #3
miguey310
1991 Honda Civic
miguey310's Avatar
Send a message via AIM to miguey310 Send a message via Yahoo to miguey310
what kinda filter do you have ? cause sum are cheap and they don't hold the pressure and they leak , another tip is when you put the oil filter lub up the gasket with sum oil to make it seal better
miguey310 is offline   Reply With Quote
Old 03-21-2010, 07:40 PM   #4
puertoricanboy90
Yes. That part with the bypass hose for oil cooling. Is it removable and/or repairable?
Old 03-21-2010, 07:41 PM   #5
puertoricanboy90
Bosch filter. But it doesn't matter what kind I have because that is not where the leak is coming from. It is coming from behind base of the oil filter housing. I'll take a pic tomorrow if I have time to clarify any confusion....
Old 03-21-2010, 07:43 PM   #6
BiG ChOr!Zo
BiG ChOr!Zo's Avatar
iTrader Rating: (1)
could be the oil cooler gasket...i had the same problem with my old 92 accord and i replaced the gasket and it was all bueno...!!!
BiG ChOr!Zo'S Garage Sale Thread v.2<--click me
BiG ChOr!Zo is offline   Reply With Quote
Old 03-21-2010, 07:55 PM   #7
puertoricanboy90
Do I have to go Honda for that f*cking gasket? Cuz everywhere I have called, even my tuning shops, has no listing for the part. It's driving me nuts... :/
Old 03-21-2010, 07:55 PM   #8
90RENOsedan
1990 Honda Civic
90RENOsedan's Avatar
check and see if its double gasketed. it could be as simple as removing a stuck on gasket.
japanese build EE4 http://nolimitimports.com/http://efcivicsedan.myfreeforum.org/
!!!---(775 SQUAD)---!!! #3 HELLA sunk squad #24
90RENOsedan is offline   Reply With Quote
Old 03-21-2010, 07:58 PM   #9
puertoricanboy90
I think I must be severely misunderstood... there is no way this is the oil filter. It is NOT double gasketed. It is not a cheap filter. The part is called an oil filter housing. The part with spindle [that the oil filter screws on to] with the oil bypass and cooling ports. It is leaking from there....
Old 03-21-2010, 07:59 PM   #10
88Hatchy
88Hatchy's Avatar
I have found that is best way to get parts like these is to find the part number yourself, then just ask for the specific part at the parts counter.
NSRacing tuned.
88Hatchy is offline   Reply With Quote
Old 03-21-2010, 08:35 PM   #11
BiG ChOr!Zo
iTrader Rating: (1)
yes you have to go and get it from the dealer...its not your oil filter but is called a oil cooler o-ring (91316-PE7-730) that is located between the oil filter housing and the block...its #19 in the diagram below for a d16a1 motor...when this o-ring goes bad it starts leaking a ton of oil and at first i thought my block was cracked but it turned out to be the o-ring...!!!
Old 03-21-2010, 11:06 PM   #12
DCRB
DCRB's Avatar
Send a message via AIM to DCRB
the gasket is like three bux...
Build Thread - My 88 ED6 Daily - 97 Vr6 Passat Wagon
Originally Posted by BETOSCOUPE View Post
Plus my boss gets mad at me because she can't hear me 1/2 the time while I am on the phone with her lol "WHAT IS ALL THAT NOISE" - Bitch..... Its my Type R foo lol
DCRB is offline   Reply With Quote
Old 03-22-2010, 04:46 AM   #13
minime-dom
i have some what of the same problem i got a d16z6 turbo and its leakin oil but i have no clue were i look under it and i cant seem to find it i think it may be leakin oil from the oil pressure switch to the turbo wut in oil line do u think i shuld get ?? or what kind of oil lines are good
minime-dom is offline   Reply With Quote
Old 03-22-2010, 04:54 AM   #14
Jockone
Op as you can see from the exploded view posted above yes it comes apart and it is an easy fix,just as an added precaution I would get new hose or hoses for the water side of the cooler/housing while I was in there.
Old 03-22-2010, 07:11 PM   #15
puertoricanboy90
That is the plan good sir. And Big Chorizo hit the nail on the head with the diagram. I ordered the part and it'll be in tomorrow. thanks guys.
01, 454, civic, filter, filters, gasket, honda, housing, leak, leaking, oil, prelude, screws, seal, spindle
