check engine light
check engine light
i just put a new gauge cluster in and now check engine light is on. hooked it up to code reader and it shows p1336 and p1337 ignition module malfunction or misfire. i deleted the codes and they just come back. would this have anything to do with the new gauge cluster? any ideas on what to check
Re: check engine light
alright thanks ill try that in the morning. do i just unplug it for a couple minutes then plug it back in to reset it? sorry for the noob questions
im assuming you have an obd2
P1336 CSF Sensor Intermittent Interruption
P1337 CSF Sensor No Signal
and yes a minute then plug back in. imma gonna look at my helms to see the problem
Check out here:
http://www.team-integra.net/forum/di...TopicID=256887
That is a code that you want to get fixed asap! It will screw up your timing and your engine!!
h kid
08-31-2005 10:14 PM
