LS-VTEC cannot set timing
Old 03-20-2010, 04:23 PM
  #26
Touching My Member
.Manny.'s Avatar
Default Re: LS-VTEC cannot set timing
I suspect the distributor. Is it oem or aftermarket??
Old 03-20-2010, 04:24 PM
  #27
Jorsher's Avatar
A newly remanufactured distributor.
Old 03-20-2010, 04:28 PM
  #28
Touching My Member
.Manny.'s Avatar
I think that is where your problem is. I had a rebuilt distributor on my dohc zc and had the same exact problem. I'm guessing something wasn't put together correctly. Had to widen the slots to get the timing down.
Try another dizzy, I'm willing to bet that it will fix the problem.
Old 03-20-2010, 04:39 PM
  #29
Jorsher's Avatar
I will try that...
But why would it work properly the first time I had it all together, took the head off, put it all back together exactly how it was, and now suddenly it's wrong?
Not saying you're wrong, just asking why in less than a couple days it would go from "perfect" to broke.
Old 03-20-2010, 08:41 PM
  #30
joker4096's Avatar
headgasket sealed fine?
Old 03-21-2010, 07:58 AM
  #31
Jorsher's Avatar
Yeah.
I'm just going to build another one.
Thanks.
Old 03-21-2010, 08:14 AM
  #32
Touching My Member
.Manny.'s Avatar
But it wasn't fine, you said you had to retard the distributor all the way back to get correct timing. I've never had to do that unless something was wrong.
Old 03-21-2010, 01:01 PM
  #33
joker4096's Avatar
what the hell could be wrong with this, it was fine when you did it before. this is just odd
Old 04-25-2010, 03:35 PM
  #34
Jorsher's Avatar
Same problem, new block/head.
Old 04-25-2010, 07:22 PM
  #35
joker4096's Avatar
wtf, try a different dizzy then i would guess
Old 04-26-2010, 07:57 AM
  #36
Jorsher's Avatar
Yeah I'm trying to source a distributor so I don't have to buy one that may not fix the problem, and am not having luck with that.
No idea where to go from here.
bnwbass
05-14-2016 12:37 PM
zx92027xz
08-11-2012 06:47 AM
brusk13
01-11-2006 07:01 PM
BABY NSX
06-15-2001 07:47 AM
Quick Reply: LS-VTEC cannot set timing
