D17a2 - d16v1 to D16y8 İntake Manifold Swap (WARNING! Large photos!)
Old 03-18-2010, 04:12 AM
despe's Avatar
Default D17a2 - d16v1 to D16y8 İntake Manifold Swap (WARNING! Large photos!)
MAP and TPS
Old 03-18-2010, 06:54 AM
jdmfreak1992's Avatar
Default Re: D17a2 - d16v1 to D16y8 İntake Manifold Swap photo
Thats cool nice job did you have to rewire any sensors?
Old 03-18-2010, 07:54 AM
Pothole987's Avatar
How long have you been running this on the car? i wanna know how long the gasket will hold up.
and this means you can put s/c's on these if it does infact work.
Old 03-18-2010, 09:37 AM
despe's Avatar
sorryy
I don't know english
i m speak turkish
Old 03-18-2010, 09:52 AM
despe's Avatar
Again , I didn't do the cable
I only extended cable. not cutting.
Old 03-18-2010, 09:56 AM
despe's Avatar
I am useing one weeks
*Gasket Oem steel. What damage there
Old 03-18-2010, 10:01 AM
SONER-VTI's Avatar
despe is my friend. he has bee nusing this intake for one week. oem gasket is made up of steel. so what kind of damage do you expect?
Old 03-18-2010, 12:18 PM
Sanji
toyomatt84's Avatar
Actually, I think the issue was not with mounting it to the head, but pulley clearance to the strut tower.
1992-2000
2001-2005
Old 03-18-2010, 11:32 PM
despe's Avatar
Default Re: D17a2 - d16v1 to D16y8 İntake Manifold Swap (WARNING! Large photos!)
Engine : D16v1
Ecu : D17a2 vtec @ 6880 rpm
Stock intake manifold
Full throttle afr 13,2-13,5......redline 11,5-11,8
Engine : D16v1
D16y8 intake manifold
Full throttle afr 13,9......redline 13-13,2
must be full throttle 13,5......redline 12,4
Old 03-19-2010, 07:04 AM
b0yg0tskills's Avatar
If someone could translate and answer some question that would be awesome.
Does the car through off any sensors?
How is the clearance from the manifold and the firewall?
Working properly?
Old 03-19-2010, 08:54 AM
SONER-VTI's Avatar
Working properly?
He didnt cancel any sensors. The clearance is 2 cm...
Old 03-19-2010, 10:14 AM
I understand that he didnt cancel any sensors i meant likedoes the car through and check engine light or some sort? And to do this swap, does it open the car to anything good as in performance?
Old 03-19-2010, 12:51 PM
Pothole987's Avatar
1992-2000
2001-2005
wow i never even thought of the pulley.
Old 03-19-2010, 12:52 PM
Pothole987's Avatar
i didn't say damage ugg... i said how long will it last.
Old 03-19-2010, 03:10 PM
despe's Avatar
I don't know on me
If comes the damage, I exchange p2r thermal gasket install.
Old 03-20-2010, 01:49 PM
despe's Avatar
BEFORE
AFTER (don't remap)
Old 03-20-2010, 03:33 PM
ChanTech's Avatar
so can i put D16y8 intake manifold to my non-vtec and will it need a aftermarket ecu?
Old 03-20-2010, 08:33 PM
seeodywhy's Avatar
What pulley? Please tell me what pulley. Not that I want to do this swap I want to know what puley needs clearence. How could the intake swap cause pulley clearence issues.
Old 03-21-2010, 07:55 AM
despe's Avatar
ecu d16v1 to d7a2
d17a2: 6880 rpm + apexi safc2
Old 03-21-2010, 08:37 AM
baron340's Avatar
Ok.. seriously guys.. He isn't the first to this swap or the last. I am very surprised he got the throttle body to fit like he did, but other than that, it's been done. I used a custom plate machined to fit the d17 TB and the IACV slot. I had some big problems trying to get this manifold to idle correclty with only a piggy back. With k-pro it works fabulously though. I don't know the differences in the engine in Turkey vs. the USDM d17, but the USDM ones have EGR. You MUST solve the EGR issue to keep from throwing a CEL. You either 1) use the d17 injector plate or 2) use k-pro. The firewall clearance isn't bad. You just have to move the AC line a little.
Old 03-21-2010, 09:48 AM
despe's Avatar
thanks. i m not speak english. sorry friends. If you want , I answer turkish
The answers
1. EGR = The cancellation, With Blind gasked- no problem.
2. İACV = Will be placed flange Later.
3. k-pro = Very expensive in turkey. apex-i safc2 I am useing
1. EGR = Kör conta kullanarak valf üzerinden iptal ettik. Problem yok.
2. İACV = Şu an motor soğuk iken rölanti düşük. Ben gaz kelebeğinden ayarladım. Flange kullanarak problemi çözeceğim.
3. k-pro = Türkiyede çok pahalı. Benim steup ımdaki kişiler için gereksiz. safc2 kullanıyorum.
Old 03-25-2010, 07:59 PM
em2-matt's Avatar
just wondering but wouldn't having a d16 intake manifold on a d17 cause some restricted air flow?
Old 03-25-2010, 10:37 PM
portaman03's Avatar
The answers
Your English is not that bad.
portaman03's Avatar
Why would you think that.
Old 03-26-2010, 08:39 AM
em2-matt's Avatar
i thought maybe the size of the outlet holes on the d16 manifold would be smaller than the inlet on the d17 head
Quick Reply: D17a2 - d16v1 to D16y8 İntake Manifold Swap (WARNING! Large photos!)
