Old 03-16-2010, 06:37 PM   #1
724chris
Default what would cause my back tire to wear on the inside?
i just got a allignment and replaced my struts and its still doing it.. im guesssing a bad trailing arm bushing?
724chris is offline   Reply With Quote
Old 03-16-2010, 07:27 PM   #2
redeg666
redeg666's Avatar
Default Re: what would cause my back tire to wear on the inside?
the alignment guy should be able to tell you why
redeg666 is offline   Reply With Quote
Old 03-16-2010, 07:38 PM   #3
ej8coupegsr
ej8coupegsr's Avatar
sounds like camber wear.. what type of suspension you runnin?
ej8coupegsr is offline   Reply With Quote
Old 03-16-2010, 08:19 PM   #4
alphalanos
2000 Honda S2000
alphalanos's Avatar
Send a message via AIM to alphalanos
irrelevant. only thing that can cause this is bent parts, or bad alignment. camber is not a major tire killer, toe is.
2000 Honda S2000
alphalanos is offline   Reply With Quote
Old 03-16-2010, 10:02 PM   #5
turnsignalandy
turnsignalandy's Avatar
is it even possible to adjust toe on 92-00 rear suspension? sounds like bent parts
1997 Honda Civic EX Sedan - Daily for 7 years - SOLD
2005 Acura RSX-S 30k miles - Totaled by a drunk driver
2005 Honda S2000 - New Daily
turnsignalandy is offline   Reply With Quote
Old 03-16-2010, 10:12 PM   #6
boxeocampeon
yeah but you should get even wear with a good toe alignment
boxeocampeon is offline   Reply With Quote
Old 03-17-2010, 01:20 AM   #7
Acuronda_SloTeg
Acuronda_SloTeg's Avatar
Send a message via AIM to Acuronda_SloTeg
yes it can be aligned, the dillweed alignment guy probably didnt notice the toe ends right in front of the gas tank under the back seat area of the car. also check for bent parts like they said. and if you are rollin slammed, im not even gonna answer why its happenin
DC Squad Member #0643
Acuronda_SloTeg is offline   Reply With Quote
Old 03-17-2010, 03:33 AM   #8
724chris
nah its not slammed just on tein stechs. what could be bent in the back??
Old 03-17-2010, 11:27 AM   #9
ej8coupegsr
well he really didnt give to much info thats why i kinda went with that.. cuz i used to have the same problem with my hatch.. but as far as the bent part goes some of the more experienced dudes should know
Old 03-17-2010, 02:07 PM   #10
turnsignalandy
camber takes a long time to show tire wear. Its toe that ****s **** up
Old 03-17-2010, 02:13 PM   #11
98civdx
Master Detailer
98civdx's Avatar
agreed
98civdx is offline   Reply With Quote
Old 03-17-2010, 09:32 PM   #12
Acuronda_SloTeg
camber would be the camber arm that bolts to the inside of the wheel wheel. as far as toe goes, it could be a really jacked up lca or a slightly bent trailing arm. and even like i said before, the toe arm is a high thought suspect
1990, accord, back, bald, del, honda, inside, outter, pilot, rear, sol, tire, tires, wear, wearing
