Camber
Old 03-09-2010, 08:08 PM
TRIAL USER
thefenixgang7's Avatar
Default Camber
Hey all, I have searched, but I am having a hard time finding anything to do with what I'm looking for.
I have a 91 Civic DX sedan and the front wheels lean in. I know it has an obvious camber problem, but I am not sure what the cause is, I have replaced the sway bar bushings, and lower ball joints, I have a camber kit on the way, but it will not 'fix' the problem, only cure the symptom. the drivers side is far worse than the passenger side. All the bushings seem to be fine, and I can not find any play in the upper ball joints (although I am going to replace them anyway.)
If you have any ideas or thoughts please let me know.
Thanks.
Old 03-09-2010, 08:18 PM
blasterman87's Avatar
Default Re: Camber
sounds like somethings bent to me
Old 03-09-2010, 08:34 PM
BiG ChOr!Zo's Avatar
Default Re: Camber
did you get an alignment after putting on the camber kit...!!!
Old 03-09-2010, 09:00 PM
lvmevo's Avatar
Default Re: Camber
PICS please.
Old 03-09-2010, 10:46 PM
jasoncanseeoh's Avatar
Default Re: Camber
Originally Posted by BiG ChOr!Zo
did you get an alignment after putting on the camber kit...!!???!
Old 03-10-2010, 05:14 AM
jonnyt1130's Avatar
Default Re: Camber
He said it's on the way. Trust me i put the skunk2 camber kit on and it made a night and day difference for my camber problems. Yes make sure you get an alignment to make sure the camber kit is properly in place. Also if your car is lowered that would make the wheels camber.
Old 03-10-2010, 07:17 AM
4g4dcruisin's Avatar
Default Re: Camber
Do your front tires look like this?
Notice how the passenger side is leaned in more towards the engine?
You dont "need" a camber kit, they only get in the way and bang **** more than anything else. If anything, your spindles are probably bent, one of them anyway.
Take your car to an alignment shop and ask for a TOE adjustment, thats all that our "double wishbone" suspension needs in order to fix excessive inner tire wear.
Anyone else who says you need to adjust the camber is full of crap.
Old 03-10-2010, 10:50 AM
Default Re: Camber
Thanks.
i must be missing something because he doesn't say anything about being on his way to get a alignment...!!!
Old 03-10-2010, 11:03 AM
Default Re: Camber
Sorry Eric but you're wrong here, the OP stated that he has a camber kit that is being shipped to him, and he will have the car aligned once the camber kit is on.
You asked if he got the alignment after he put the kit on, but he doesnt have the kit yet.
Old 03-10-2010, 12:31 PM
Default Re: Camber
my mistake
op make sure you get a alignment after installing the camber kit...!!!
Old 03-10-2010, 12:41 PM
Default Re: Camber
Eric, did you call me the other day? I thought i saw you called.
Old 03-10-2010, 12:50 PM
Default Re: Camber
yes since i was gonna let you know about the white ed3 sedan trade for your eg out in san diego...i sent the link to your marketplace ad instead...!!!
Old 03-10-2010, 12:54 PM
Default Re: Camber
Alright, my minutes are low for the next couple days. i havent been answering the phone recently.
butter99
Suspension & Brakes
02-04-2010 04:53 PM
TrueJimmy26
Suspension & Brakes
07-01-2008 09:08 AM
RedlineRex
08-03-2006 04:37 AM
Jason C SBB
09-08-2003 08:09 AM
teg21
07-09-2002 09:46 AM
Quick Reply: Camber
