HELP. lug nut key stuck on lug nut
Old 03-07-2010, 03:56 PM
TRIAL USER
scorchmuffins's Avatar
Icon3 HELP. lug nut key stuck on lug nut
Okay, so i was switching over to my summer tires and in the process of loosening my rear tires, the lug nut key snapped. cheap piece of crap. Either way, any ideas how to get it out, i don't have a welder.
http://tinypic.com/r/50s3us/6
http://tinypic.com/r/28s0oia/6
http://tinypic.com/r/2e5phj8/6
please help. thanks.
Old 03-07-2010, 04:02 PM
talkerty's Avatar
Default Re: HELP. lug nut key stuck on lug nut
drill it out or just hook some vice grips on the lug nut and try to turn it off and just replace it.
Old 03-07-2010, 04:04 PM
Anon51's Avatar
take the rest of the lugs off using a breaker bar. if you have a welding machine around you can weld something to the back of the key thats stuck in there and take the piece out OR drill into it and use a self tapping screw to take that piece out.
Old 03-07-2010, 04:12 PM
90_EX_Civic's Avatar
op, what ever you do, don't do this,
https://honda-tech.com/forums/general-discussion-debate-40/so-dont-buy-vw-2684546/
get a drill and drill as much of it out, and then use a allen key to get it out. ether that or get a cheap 12 point socket just big enough (more like snug) and hammer it on to that lug nut and take it off like that.
Old 03-07-2010, 04:17 PM
TRIAL USER
https://honda-tech.com/forums/showthread.php?t=2684546
Well i never planned on cutting my rim ^^. but since all the stores are closed, ill try the drill bit thing tomorrow, i have to buy a new key to get the other nuts off too.
please keep the ideas coming too. thanks.
Old 03-07-2010, 04:21 PM
Resident Gearhead
BryanM.'s Avatar
Drill a hole down the middle, thread the hole with a tap, screw in a bolt and pull the broken part out by pulling on the bolt.
Old 03-07-2010, 04:28 PM
Anon51's Avatar
while you wait for the stores to open up again. maybe spray your lugs down with some PB blaster or other penetrating lubricant?
Old 03-07-2010, 04:31 PM
TRIAL USER
Alright, i did that, might help with i drill it tomorrow.
Old 03-07-2010, 04:38 PM
TRIAL USER
i have to say though, at least my key broke on my first back tire swap, so now my fronts are on yokohamas and backs on winter tires, my axle will still be all good
Atauto
Honda CR-V & Element
12
09-22-2015 09:52 PM
blaze.1
10-05-2009 05:51 AM
BrandonClaps
08-29-2002 08:50 PM
Quick Reply: HELP. lug nut key stuck on lug nut
