Last edit by: IB Advertising
- Honda Accord: Why is my vtec solenoid leaking oil?
Guide to diagnose touble and recommended solutions.
Why is my VTEC solenoid valve leaking?
#26
Re: Why is my VTEC solenoid valve leaking?
Yeah I used brake cleaner on the whole area last weekend, which is how I traced the leak to the gasket in between the VTEC valve and solenoid, NOT the gasket between the valve and the engine head.
#28
I dunno, I'll feel better when the damn thing is actually fixed.
I'm a bit of a perfectionist and can't stand even the smallest leak of any sort.
#31
VTEC oil leak seems to be gone. However it appears there is still oil leaking from other places and dripping down onto and burning on the exhaust header, as I explained in this thread: https://honda-tech.com/forums/tech-misc-15/found-more-oil-leaks-oil-dipstick-2736333/
#32
#33
https://www.acuraautomotiveparts.org...ylinder-head-2
#34
You can usually fix the leak without buying new gasket and instead (1) cleaning old gasket and solenoid mating surfaces with brake cleaner and (2) applying a thin layer of HondaBond to the gasket. Then torque to spec.
#35
Thank you. Local Honda parts department helped me figure out the o ring and top gasket, not just the one with the filter and problem solved. I didnt even have to take anything off but the wiring harness for those two fixes on day 2. Keeping my 99 rolling. I truly appreciate the replies and glad this thread was still alive.
Master23
17
04-01-2018 08:48 AM
Master23
06-05-2006 07:34 PM
