Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura RSX DC5 & Honda Civic EP3
Old 02-21-2010, 10:00 AM   #1
eghatch4sale
eghatch4sale's Avatar
Send a message via AIM to eghatch4sale
Default PLEASE HELP k24a2 swap into a 02 type s questions
Ok i have wasted the last 3 hours of my day searching on what all that needs to be done to put a 04 acura tsx motor into a 02 acura rsx type s ..............
all i seem to come up with is a bunch of people just guessing on this works this doesnt work !!!!!! or the k24a2 into the base model
from what im reading i can use my stock harness and mounts except i will need to use a crv bracket not mount ???? or some people say the crv mount some say the bracket ????
will the tsx intake manifold fit into the rsx ????? some people are saying that it will some people say it wont some people say u have to cut your radiator support ????
what will require to use the stock rsx type s intake manifold ??????
any other pointers would be appreciated sorry i am a noob to k series and rsx's but i have been searching and really dont have the time to search anymore and need to get this car running ASAP
PLEASE DONT LET THIS THREAD TURN INTO AN OPPION THREAD im not putting the k20a2 head on the tsx block i am just wanting to run the tsx motor in the rsx
THANX IN ADVANCE
eghatch4sale is offline   Reply With Quote
Old 02-21-2010, 11:26 AM   #2
Type-Spaz
DC5/EP3 MOD :)
2005 Acura RSX
Type-Spaz's Avatar
Zack Zweifel (spaz)
Send a message via AIM to Type-Spaz
Default Re: PLEASE HELP k24a2 swap into a 02 type s questions
I have the k24a2 in an 05 Type-S
it was simple and easy.
You do need the CR-V bracket yes.
The TSX manifold will fit in the rsx. You'll make more power with it. I wouldn't convert but if you want a different manifold buy an unmodified RBC intake manifold.
05 Integra Type-S
K24A2 swap with Full Race/Precision 6262 Turbo 438whp
www.urbandisturbance.net
Type-Spaz is offline   Reply With Quote
Old 02-21-2010, 12:12 PM   #3
d16_2_k20
d16_2_k20's Avatar
Are you missing anything/power loss with a lower rpm redline?...Just curious
02 nhbp DC5 Type-S
d16_2_k20 is offline   Reply With Quote
Old 02-21-2010, 01:02 PM   #4
Type-Spaz
DC5/EP3 MOD :)
2005 Acura RSX
Type-Spaz's Avatar
Zack Zweifel (spaz)
what does RPM have to do with power? It's all on how the engine is built and what it is built for.
I make 230lb of torque by 2300rpm.... 2300! Thats more than some have HP and so instantly. I may only rev to 7600 but I make torque all the way across the board and make 315whp at 7600.
High RPM doesn't always mean more power...
05 Integra Type-S
Old 02-21-2010, 02:10 PM   #5
eghatch4sale
So all I need is a crv bracket then and the tsx motor will go right in plug and play ? Don't need to modify anything else ?
Old 02-21-2010, 08:07 PM   #6
Type-Spaz
DC5/EP3 MOD :)
2005 Acura RSX
Type-Spaz's Avatar
Zack Zweifel (spaz)
you have to swap some sensors also. But other than that it's pretty much the same engine. You'll have to make a custom intake. And if you keep the k24 manifold you'll need the karcepts adapter for your throttle body
05 Integra Type-S
Old 02-21-2010, 10:23 PM   #7
eghatch4sale
Do u know off hand what sensors I will need to switch ??? And the tsx intake manifold will work but I need to use the rsx throttle body ...... Will the radiator support need to be notched or will ot be a direct fit ?
Old 02-22-2010, 08:11 AM   #8
eghatch4sale
Also can I keep my power steering and air condtioning with using the tsx swap ???? Also I read somewhere that u need to use the rsx water neck ???? Please help with as much infromation as u can !!!!!! need to get this car running soon as I pick up the motor !!!!!!! Any and all help is appreciated !!!!!
Old 02-22-2010, 09:24 AM   #9
Type-Spaz
DC5/EP3 MOD :)
2005 Acura RSX
Type-Spaz's Avatar
Zack Zweifel (spaz)
Alright here we go....
1) I only swapped cam position sensors.. they say to swap the knock sensor but the k20 knock sensor did not read on my k20, so I solder on a k24 knock sensor plug onto my k20 wiring harness and run the k24 knock sensor.
2) I didn't notch the radiator support but I've seen some say the same thing about notching so not sure...
3) I used all the components off of my k20 for the k24. So water pump, housing, thermostat, ac, ps, blablabla
3a) For the water neck you need to use the k20 water bypass tube but k20 thermostat housing.
05 Integra Type-S
Old 02-24-2010, 08:47 AM   #10
eghatch4sale
what crv bracket do i need also ?????
Old 02-24-2010, 12:01 PM   #11
Type-Spaz
DC5/EP3 MOD :)
2005 Acura RSX
Type-Spaz's Avatar
Zack Zweifel (spaz)
CRV passenger side motor bracket PART #11910-PPA-000
05 Integra Type-S
Old 02-24-2010, 12:02 PM   #12
Type-Spaz
DC5/EP3 MOD :)
2005 Acura RSX
Type-Spaz's Avatar
Zack Zweifel (spaz)
05 Integra Type-S
Old 02-24-2010, 12:15 PM   #13
eghatch4sale
awsome thanx alot man!!!!!! motor was just ordered today should be here beigining of next week
Old 02-24-2010, 05:31 PM   #14
kobeballer96
kobeballer96's Avatar
Send a message via AIM to kobeballer96
sweet congrats man, i wish i had a k24a2 in my ep.
|EP3 Squad Member #9|
Originally Posted by sPcIaLkSeRiEs View Post
lol correction there buddy not vtech we have i-vtech thats a big difference.
kobeballer96 is offline   Reply With Quote
Old 02-25-2010, 06:55 AM   #15
turboteg2nv
turboteg2nv's Avatar
SlowEP3
How much did you buy the motor for?
'03 SSM RSX-S: with some bolt-ons & SSR ///
'05 NHBP EP3: sold _ _ _'96 CGP DC2 ls-t: sold
Originally Posted by fast+forward View Post
Its a bad economy when snitching is only worth $500 skunk2 credits
turboteg2nv is offline   Reply With Quote
Old 02-25-2010, 08:40 AM   #16
eghatch4sale
Got the motor for 1100 plus 250 shipping from florida 68k on the motor
Old 02-25-2010, 10:31 AM   #17
turboteg2nv
SlowEP3
For just the longblock?
That's a helluva deal
Old 03-12-2010, 06:51 PM   #18
k+jcivics
TRIAL USER
got the tsx eng k24a2...im new to this also...i have a type s 02 rsx...is the waterneck the tube coming from the thermastat housing? or just keep tsx one on?does the whole thing have to be replaced to type s.....i put types one on wont fit rite...im keeping stock tsx manifold...just ordered karcepts adapter for throttle body...i have no clue wat goes where withe the hoses....i appreciate all the help i can get...if possible show pic to see how it looks....thanx
k+jcivics is offline   Reply With Quote
Old 03-12-2010, 07:36 PM   #19
NC-B17A
NC-B17A's Avatar
We are doing the same swap in my sons 02 Type-S. In for any more info
92 GSR
03 Element
NC-B17A is offline   Reply With Quote
Old 03-12-2010, 10:35 PM   #20
k+jcivics
TRIAL USER
wat u have to change on engine to make things work....i know the mount has to be changed....
Old 03-18-2010, 01:06 PM   #21
k+jcivics
TRIAL USER
i changed the water neck and thermastat housing....got that all figured out...now on the front engine mount the type s mount wont bolt to the tsx engine....so do u use a tsx mount ? thanks i really appreciate all the help i can get....
Old 03-18-2010, 01:19 PM   #22
NC-B17A
NC-B17A's Avatar
You have to get the CR-V/Element braket mount to maye up one of the motor mounts.
92 GSR
03 Element
Old 03-19-2010, 06:57 AM   #23
SkoundrelUSA
cute little bastard
SkoundrelUSA's Avatar
The stock front mount should work. In fact, all the stock mounts work. Like Type S paz already stated, you only need the CRV passenger bracket.
(I have a K24A2 in my EP3 in case the OP thinks I'm guessing)
"So whats the deal with politics? I don't get it...Am I right people? "
SkoundrelUSA is offline   Reply With Quote
Old 03-19-2010, 05:11 PM   #24
NC-B17A
NC-B17A's Avatar
Type-'S'paz or anyone else can you bolt the Type-S oil pan onto the K24A2 without doing anything to the oil pick up?
92 GSR
03 Element
Old 03-19-2010, 05:13 PM   #25
Type-Spaz
DC5/EP3 MOD :)
2005 Acura RSX
Type-Spaz's Avatar
Zack Zweifel (spaz)
no the baffles are different. No need to swap them unless you are building the block and head for high reving purposes
05 Integra Type-S
02, control, crv, disable, intake, k24a2, manifold, mount, pictures, rsx, runner, sensors, swap, tsx, type
