Acura MDX / RDX
1998 Odyssey Misfire only on COLD start up
Old 02-17-2010, 07:42 PM
SD98ODY's Avatar
Default 1998 Odyssey Misfire only on COLD start up
Hi Ihave a 98 Odyssey 2.3Lwith 223k miles, on cold start up the engine misfires a lil bit for a few seconds then goes away, doesn't affect driveability, sometimes it will trigger the check engine light and P0302, and P01399 are the only codes, I've already replced all the plugs wires and cap-it was an everyday problem, now it's intermitent. Any thoughts be much appreciated
Old 03-05-2010, 08:01 PM
SD98ODY's Avatar
Default Re: 1998 Odyssey Misfire only on COLD start up
Ok, I found oil inside the distributor cap, the oil would build up at the bottom affecting spark getting to cylinder#2. I replaced the distributor assembly, everything was fine for a couple of weeks and I'm now back to the same problem, momentarally misfiring on cold start up. I might try adjusting the distributor a lil bit??
Old 03-06-2010, 02:40 PM
In a Junkyard near you.
Ross 2.0's Avatar
I JUST had a bout with this on an Accord today. I would like to know what the fuel pressure is and what state you live in.
It's probably low fuel pressure though.
sharaaz2001
11-18-2016 04:01 AM
Brando76
01-01-2013 02:06 PM
Laura Ilkenhans
09-05-2012 08:36 PM
cvcntn
04-20-2012 07:25 PM
Mike VR6
05-10-2006 08:50 AM
Quick Reply: 1998 Odyssey Misfire only on COLD start up
