6th gen f23a1 to f20b swap thread
Old 02-07-2010, 04:59 PM
triggerman77's Avatar
Default 6th gen f23a1 to f20b swap thread
Ok I started on the swap yesterday. I got the F20B in. Now the pain in the *** starts. wiring no more BS'n. I plan to somewhat document the swap. At least with a few photos. So maybe this will encourage more 6th gen swaps to the F20B. I will be doing this by myself so my only issues will be with the wiring and fighting the CEL. So wish me luck.
by the way i had the f23a1 out 4 hours and switched all the obvious stuff and dropped the F20B in pics coming
Old 02-07-2010, 05:02 PM
Default Re: 6th gen f23a1 to f20b swap thread
Originally Posted by triggerman77
Hi i was wondering about the sensor in the center of intake stock one had 2 wire plug the one on the f20b has 3 wire plug
wire colors are
stock harness
red/yel
black/yel
f20b harness
black/blue
yel/black
black
any clue on this im lost ???
also im tryin to run f20b ecu Will i need to add knock sensor or not??
OK i was wrong i forgot the sensor on the front of my new intake. it is just like the one on the back of my stock intake and its three wires.
And honestly this swap was fairly simple everything pluged in except the dizzy.and all the colors matched up from harness to harness. Also i compared the pins at the ecu and they are the same color for color except stock harness has one extra blue/blk wire and the f20b harness has one extra red/blue on pin B16 that controls the IAB,s
Now the car will run on the stock ecu but when i put the f20b ecu in the fuel pump will not come on. Any clue as to what i can do to get fuel pump on with F20b ecu. and it does have fire with F20b ecu just no fuel ??????? Thanks
Old 02-07-2010, 05:06 PM
pic
Old 02-07-2010, 05:31 PM
I forgot to mention i broke the vacuum hoses off the IAB box under intake so if anyone knows where to get one please LMK pm me
Old 02-07-2010, 05:40 PM
One more pic will post more pics tomorrow ok this one didnt work WTF
File Type: zip
Old 02-07-2010, 05:47 PM
ok one more time pic more tomorrow ok i screwed up wrong pic damn it
Old 02-07-2010, 06:22 PM
davey5300's Avatar
Loving the swap dude!!! How bad was the wiring? Let me know how it performs when it's all done because I'm thinking about swapping an F20 into my CD5 in the future
Old 02-07-2010, 07:06 PM
The wiring was simple on my car or so i say i dont have it right yet BC im not running the f20b ecu yet. Check out nusdogg i think he has a 5th gen with f20b. and THANKS i am bout to go crazy tryin to figure out this fuel pump issues but it felt good to hear that baby fire up and idle with the stock ecu.
Old 02-08-2010, 03:16 PM
HELP!!!!!
Old 02-09-2010, 10:09 AM
Ok today i talked to someone who has been doing engine swaps since 1997 he say no fuel pump sounds like a resistor n the ecu. So he told me to use a jumper wire to make fuel pump come and see if the car will run, So i did just that a the car will run with the f20b ecu but it will only rev to around 6200 rpm any way i drove it to let it warm up and then when i got on it NO VTEC. So now i know the VTEC is not kicking in and the fuel pump is not working unless i jump power to it. ANY IDEAS why it only revs to 6200 with PCB ECU and why vtec is not kicking in ?????
Old 02-09-2010, 10:15 AM
GhostAccord's Avatar
Is the check engine light on? It sounds like you may have a bad ECU or some crossed wires.
Old 02-09-2010, 12:24 PM
yes its on but i have not checked codes yet and i know the o2 sensor in not hooked up BC header is not yet hooked to the cat yet. And yes i am thinking the same thing bad ecu.
Old 02-09-2010, 05:45 PM
Good news i hope. jspecauto.com is sending me a new ECU but it for a automatic tiptronic. he said it would throw CEL because it would be looking for the auto tranny.
Will this possibly cause a rev limiter? Any thoughts on this?
Old 02-09-2010, 07:39 PM
crx_91si's Avatar
if your still obd2b, your fuel pump isn't coming on because the Pin on the PCB ecu is different. You gotta swap the A15 pin (grn/blk) i believe to A14 position and that **** should start right up.
Using the Auto version of this ECU wont work either. Rev limiter at 5k, no vtec. I tried running a auto PCF ecu and that was my result.
My JDM H23A is running a PCB ecu and these are the steps i had to take.
Let me know how you make out. Oh, and you can get the IAB box from Honda P/N 36361-PT2-014 VACUUM TANK
mike
Old 02-10-2010, 06:11 AM
Ok thanks will try that today. i hope u r right
Old 02-10-2010, 08:44 AM
DAMN CRX91SI I O U BIG!!!!!
Ok it was A15 but the wire was green/yellow. I tried it in A14 and it did nt work so i tried it in A16 and the fuel pump came on. So i drove around a few minutes to warm up and when i stoped and got down on her i could tell something was better and then when it hit 5500 RPM VTEC kicked in and i was through the gears and running 120 mph in no time. Damn i love it !
So the conclusion is i now have one bad *** 6th gen accord. This F20B is way more than i was expecting!!
THANKS AGAIN TO ALL WHO HELPED ME THROUGH THE SWAP!!!!
Old 02-10-2010, 08:46 AM
Now i only need one thing. Power steering bracket. If anyone knows where to get one pease LMK Thanks
Old 02-10-2010, 09:11 AM
crx_91si's Avatar
alright i was on the right track though. I knew it was one of thoes pins. i would have taken a look and snapped a pic if you didn't figure out. glad to hear it's up and running. I got my power steering bracket from honda. I think it was like $55 or $60.
best of luck man.
mike
:EDIT: Power Steering Bracket 56994-P5M-000 $80.30
Old 02-10-2010, 10:08 AM
damn 80 buck thats robbery. For that little bracket are they crazy I now someone has one laying around. Come on all these guy that delete P/S and A/C for HP. Theirs gotta be like at least a friggin 100 of these brackets layin around here and there. Help a brother out i will Pay for it just not $80 LOL
Old 02-10-2010, 10:19 AM
Oh yea i gotta give props to jspecauto.com. I checked my oil when i got back and it is as clean as it was in the bottle. I was amazed and very happy Thanks guys
Old 02-10-2010, 10:36 AM
OK i just hung up the phone with my local honda dealer that bracket is $110.77 i told him that was crazy and i was looking for a used one first. My wife might just have to drive the Z71 and i will gladly drive my new SIR-T Accord with Armstrong power steering. lol
Old 02-10-2010, 10:46 AM
I'm dropping my PS and looping it with a reservoir. :thumbup to Armstrong Steering!
There are a few people with a manual/power steering modified set-up.
Oh yeah! Note: I have heard that in some places finding a used 97-01 Prelude power steering bracket for much cheaper than the dealership isn't the easiest thing to do. It's probably the most popular F/H (F22B/H23 DOHC) swap bracket out there.
Old 02-10-2010, 11:50 AM
crx_91si's Avatar
if your accords are anything like my CL, then driving without power steering is going to suck big time. I muscled it for about a week before i couldn't take it anymore. It's definitely not like driving a CRX or an Eg hatch with no P.S.
and $ 110....f*ck that
Old 02-10-2010, 12:58 PM
Yea it is a bitch I got a pm from H/T member he said he has one $20 plus shipping from canada $25 im kinda weary about sending money. and im waiting for a pic
Old 02-16-2010, 03:34 PM
jr_deleon's Avatar
Remember your PM when you told me about this and I said the PCB may have inputs and outputs in different locations than yours which is why that pump wouldnt prime/run? Now go enjoy your motor bro. Im happy you got her going!
Quick Reply: 6th gen f23a1 to f20b swap thread
