Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 02-05-2010, 09:51 AM   #1
blk600cc13
Default Fill Manual Transmission Fluid... Stripped Filler Bolt
1990 Civic. Removed halfshafts and repaired those and in the progess, tranny fluid spilled everywhere. Figured I'd change it anyway. Took out the drain bolt and the rest spilled and when I looked at the filler bolt, someone before me must have went to town with that bolt! The head was stripped bad and tighter than the 33 ft. lbs it called for. Friends and I messed with it for about an hour and won't budge and the head of the bolt is stripped bad. Was like that from before. Won't move.
So anyway, here's my situation. The car is ready to go, but has no fluid for the manual transmission. Can NOT remove the filler bolt to fill it there. And I hope I can pour fluid in somewhere else in order to be able to drive this again without buying a new tranmission or taking it out and getting it to a machine shop. Really don't wanna take it out of the car.
What can I do? Can I fill it with the fluid it calls for somewhere else? Thanks.
Stock 90 Civic.
blk600cc13 is offline   Reply With Quote
Old 02-05-2010, 10:04 AM   #2
blk600cc13
Default Re: Fill Manual Transmission Fluid... Stripped Filler Bolt
Is it possible to fill it from where the speedometer cable is? Just pull that out and fill it with 2 quarts of 10W-30 like it calls for? Please help, gotta get this stuff done asap
Old 02-05-2010, 11:45 AM   #3
907civic
yes i fill my h2b ys1 tranny through the speedo everytime you just need a long *** funnel with a tip that fits in da speedo..but i always pull my fill and watch for when it starts to come out to tell if im full.. and i think my tranny takes a lil more then 2 quarts but im not quite sure cause i havent touched my car for like 5 months(its winter)..if 2 quarts is the oem capacity of your tranny then go for it..
907civic is offline   Reply With Quote
Old 02-05-2010, 11:56 AM   #4
D16SiHatch
D16SiHatch's Avatar
Send a message via AIM to D16SiHatch
what he said. pull the vss out and fill it through there. i do it this way because it's just easier than going sideways through the fill hole.
00 BMW 323i, black int, sport pkg, 5 speed
95 ej1, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, t3/t4 10psi
D16SiHatch is offline   Reply With Quote
Old 02-05-2010, 01:18 PM   #5
crxjarred
crxjarred's Avatar
Send a message via MSN to crxjarred
if your into a little work there is a plug under your starter that i have pulled out and poured it into there and i watch threw the fill hole for it to come out
00 ex coupe.. hit and run totaled
98 accord dd.
93 gsxr project bike..
crxjarred is offline   Reply With Quote
Old 02-05-2010, 01:24 PM   #6
90_EX_Civic
1991 Honda Civic
My Garage
90_EX_Civic's Avatar
i've always used the little breather hole on top of the tranny. takes a while, but i don't have to take of anything to get to it. just use a small tube and squeeze.
90_EX_Civic is offline   Reply With Quote
Old 02-05-2010, 01:48 PM   #7
blk600cc13
Thanks guys. Well first off, that filler bolt is NOT coming out unless it gets to a machine shop. Pipe wrench, regular wrenches and anything and no budge. WD-40 sprayed didn't help either. The head of the bolt is so stripped anyway so I'm giving up there.
Anyway, here is what I have done. I took out the drain bolt (the one where you just use a 3/8 ratchet and loosen it that way) and let all the fluid drain out. It's all dry... no more fluid.
Now I took the speedo cable off (see pic) but I cannot get oil in there. Just spilled all over the place.
PIC - http://img41.imageshack.us/img41/7731/pic1pp.jpg
So as of now, sitting here with filler bolt stripped and won't move, speedo cable disconnected and no fluid in tranny (all fluid drained).
So here's my question... if I leave the drain bolt out and fill it through an opening, once I pour it in, will all the fluid travel down and exit out the drain bolt hole?? Because just so I'm sure it will be lubricated, I was thinking of pouring some fluid in somewhere and just to be sure it gets there, leave the drain plug out and if everything goes right, it should drip right down where the drain plug is. And if that works, then put the plug back on, and fill it up with the 2 quarts. *I know nothing about manual transmissions*
Any advice would be great. Thanks
Old 02-05-2010, 02:11 PM   #8
4drEF
4drEF's Avatar
LOL!
you don't need to take the speedo cable out.
It's the gear drive (people call it a VSS, but it's not) that the cable plugs into.
If all else fails, take an axle out and fill the tranny until oil just starts to spill out. That's properly full.
All of my posts should be considered for being made into a sticky.
4drEF is offline   Reply With Quote
Old 02-05-2010, 02:30 PM   #9
Andy Hollis
Andy Hollis's Avatar
I've solved this before by welding a large nut to the fill bolt head. Came off with wrench and long breaker bar.
--Andy
Andy Hollis is offline   Reply With Quote
Old 02-05-2010, 04:00 PM   #10
907civic
Originally Posted by 4drEF View Post
LOL!
just like he says.. you should be taking out the speedo cable gear drive and just leave the cable connected to it..most gear drives use one 10 mm bolt to hold them in place, that bolt is located at the base of the drive where it hits the tranny.i usually had to use a 10mm socket with a long extension and a swivel to get that bolt out.. once you get the bolt out just pull up on the drive with the cable connected to it and slightly wiggle and it will pull right out and reveal a 3/4" hole or so.. then you can FILL with a funnel..and dont worry about leavin the drain plug out to check if oil gets there unless you realllly wanna be sure but any oil put in the tranny from the speedo or the tiny breather all makes it to your gears and will do the job..
Old 02-05-2010, 04:46 PM   #11
EJ1_Sleeper
EJ1_Sleeper's Avatar
Send a message via AIM to EJ1_Sleeper
lol it looks like your speedo came apart, try and pull out the sensor its self, youll have a nice opening to get a hose and filler up (been filling honda trannys like this for years now)
theres a flat head groove you should be able to slip a flathead in and pry it up and down till you can remove it fully.
89 hatch - traded
91 teg - sold
11 CRZ - daily gas sipper
EJ1_Sleeper is offline   Reply With Quote
Old 02-05-2010, 04:51 PM   #12
beansandrice
beansandrice's Avatar
LOL! This si funny stuff. But yea if you cannot get the VSS out (one 10mm bolt and its off with a pull) Then take off the Reverse light sensor (two wires coming off it) and fill it through there. I would use syncromesh fluid but that is up to you.
Originally Posted by shiroun;
I got jumped about a week ago and one of the kids jumped me bashed my phone when he kicked me. I'm on a **** nokia for a few more days.
beansandrice is offline   Reply With Quote
Old 02-06-2010, 10:03 AM   #13
acmoc
acmoc's Avatar
https://www.facebook.com/profile.php?viewas=100000686899395&privacy_source=timeline_gear_menu
Yea, gm synchromesh, same price as oil but better for your tranny
FlickR
acmoc is offline   Reply With Quote
Old 10-08-2010, 10:27 AM   #14
nphonda91
i Have the same problem i still cant get the oil in i need help asap!!! can i do it threw the axel???
nphonda91 is offline   Reply With Quote
Old 10-08-2010, 11:44 AM   #15
adamyee
adamyee's Avatar
Send a message via AIM to adamyee
dude has no one ever taken out their reverse light switch?! its big, easy to remove and gives u easy access.
adamyee is offline   Reply With Quote
Old 10-08-2010, 11:52 AM   #16
BiG ChOr!Zo
BiG ChOr!Zo's Avatar
iTrader Rating: (1)
pop off the axle,lift the car up on one side like the dukes of hazard and fill up tranny with fluid through driveshaft
BiG ChOr!Zo'S Garage Sale Thread v.2<--click me
BiG ChOr!Zo is offline   Reply With Quote
Old 10-08-2010, 11:54 AM   #17
BrayzieEF9
BrayzieEF9's Avatar
x2 THIS!!! I always fill through the reverse switch, it's so easy.
BrayzieEF9 is offline   Reply With Quote
Old 10-08-2010, 05:05 PM   #18
shawn_crx
shawn_crx's Avatar
LOL.... I can't believe nobody suggest the right thing to do....
Go to Autozone buy the bolt extractor set kit
http://www.autozone.com/autozone/cat...oductId=532381
shawn_crx is offline   Reply With Quote
Old 10-08-2010, 05:15 PM   #19
Nooch
1990 Honda Civic
Nooch's Avatar
Here at Honda-Tech, we don't like going to Vatozone. We prefer to ghetto rig the **** out of everything first. Then when all else fails go to Vatozone with your head bowed in shame.
Nooch is offline   Reply With Quote
Old 10-08-2010, 07:26 PM   #20
JeffBro
JeffBro's Avatar
Take the speedo sender gear out and fill it up and be done with it
JeffBro is offline   Reply With Quote
Old 10-09-2010, 03:16 PM   #21
bgdriver
1990 Honda Civic
bgdriver's Avatar
reverse switch!
FAKLAD
bgdriver is offline   Reply With Quote
Old 10-09-2010, 03:32 PM   #22
beansandrice
Dont mean to be an a$$ but you guys dont think. Its been about 8 mos...... Dont you think he got oil in his trans by now?
Old 10-09-2010, 04:12 PM   #23
BrayzieEF9
BrayzieEF9's Avatar
LMAO I just notice, blame the guy that bump the thread.
Old 10-09-2010, 06:09 PM   #24
singlecamsaint
singlecamsaint's Avatar
i wouldnt do this it even says in the maunal that if you remove that bolt the pinion could drop in he transmission, take the starter off and do it that way, its a 19mm plug and its in the top, this is how i do it with no problems what so ever, its a little extra work but youll get around fooling with a stripped bolt
singlecamsaint is offline   Reply With Quote
Old 10-10-2010, 04:13 AM   #25
slywfbpsi
slywfbpsi's Avatar
slyonefoya slyone4ya swomack@carolina.rr.com slyone4ya
Send a message via ICQ to slywfbpsi Send a message via AIM to slywfbpsi Send a message via MSN to slywfbpsi Send a message via Yahoo to slywfbpsi Send a message via Skype™ to slywfbpsi
Why do all that when you can just do
Originally Posted by bgdriver View Post
reverse switch!
Sly Gotta catch me first!
http://slyonefoya.mybrute.com/
slywfbpsi is offline   Reply With Quote
add, b18b1, bolt, cable, drain, fill, fluid, hole, honda, manual, moter, pull, speedo, stripped, tranny, transmission
