White smoke coming out of my exaust....Help...Intake mani problem
Old 02-01-2010, 09:53 PM
Etorres325's Avatar
Default White smoke coming out of my exaust....Help...Intake mani problem
Heres my Problem.
After attempting to install a skunk 2 intake manifold on a d16y7 and not succeeding, i decided to re install the stock one just because i needed the damb car to get around.
Today i re-installed the stock manifold with new gasket. I had trouble remembering where all the rubber hoses connected ( to and from the TB and IM to the engine) so i just started connecting them according to what seemed right.
After, I turned on the car and noticed smoke. i thought i was normal for the new gasket, but after revving the engine a little but i began to see huge clouds of white smoke coming out of the exhaust. i dont know what it is, it doesnt smell like gas or exhaust and i need help solving this.
Also, im only running 1 o2 sensor so i have a feeling this could be contributing to the problem
Im hoping someone has a picture of their d16y7 intake manifold where i can see the hoses and their proper positioning. Or someone who knows what my problem is and could possibly help me out.
Thanks...
-hope i didnt fk up my ride :/ 96 midori hatch
Old 02-01-2010, 09:57 PM
93egSLEEPER's Avatar
Default Re: White smoke coming out of my exaust....Help...Intake mani problem
you have a coolant line hooked up to your TB. recheck where all your hoses are routed.
Old 02-01-2010, 10:06 PM
Etorres325's Avatar
ok thanks i thought that would be the problem.
But now the problem is that i dont know which line goes where..i didnt take it apart but i had to put it back. anyone have a diagram or pic for the d16y7
Old 02-01-2010, 11:03 PM
_kiid's Avatar
you can have a long coolent hoes go to motor to the iacv
n leave the 2 ports on tb open if that helps lol
Old 02-01-2010, 11:17 PM
DCRB's Avatar
Water Lines:
Vacuum Lines:
found at www.hondaautomotiveparts.com
Old 02-01-2010, 11:25 PM
Etorres325's Avatar
thanks for the help guys this is exactly what i was looking for. i will let you guys know how it goes in the morning
Old 02-02-2010, 08:16 PM
Etorres325's Avatar
So.. i followed the diagram from above as well as this one
I still had white smoke coming out of the exaust and when removing the throttle body, i could see some coolant in the manifold. So its obvious thats the problem. now im just wondering why.
I did everything how im supposed to: now the only thing i can think of would be to change the throttle body gasket. Would this make a difference?
If anyone out there can take pictures of how their hoses are set and post them here, it would be really appreciated.
Thanks to all who have helped so far
Old 02-02-2010, 08:40 PM
Etorres325's Avatar
bump..help
Old 02-02-2010, 09:36 PM
i honestly dont know what more we can do for ya bud. we told you what we thought the problem more than likely is, gave you a digram and told you to switch the hoses around. without being there to do it for you its pretty much done. Only other thing it could possibly be, and this is a LONG shot is your headgasket, but it should not have blown just taking of the IM.
Old 02-03-2010, 04:49 AM
bigD's Avatar
your IM gasket may be torn around the coolant passage
Old 02-03-2010, 06:50 PM
Etorres325's Avatar
that might be it, i couldnt get the whole old gasket off so i sanded it down but there was still some left. im going to try replacing those. i just came home from buying them
Old 02-03-2010, 06:53 PM
JdmOdz's Avatar
coolant!..
vonttcha
11-11-2009 06:54 AM
matix
09-13-2006 06:36 PM
DriveSlowHomie
10-07-2005 08:13 PM
Maximo
06-17-2002 08:20 PM
Quick Reply: White smoke coming out of my exaust....Help...Intake mani problem
