Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 01-29-2010, 05:31 AM   #1
Cowtit
Cowtit's Avatar
Default overfilled master cylinder....cause this?
I'm having brake issues on my wifes 2000 jetta. Changed the brakes and now I can't get them bled properly, just can't get a stiff pedal. They will lock up, but I have to push it to the floor. Then I noticed that I've overfilled the reservoir, would this be causing my problem? I'm so fed up at this point I'm about to take it to a brake shop...
"Whenever you find that you are on the side of the majority,
it is time to pause and reflect."
- Mark Twain
Cowtit is offline   Reply With Quote
Old 01-29-2010, 05:34 AM   #2
MSchu
My Name is Nobody
MSchu's Avatar
Default Re: overfilled master cylinder....cause this?
I doubt an overfill can cause a soft pedal. it's just a Reservoir.
Originally Posted by Targa250R View Post
Bourdais is like the Michael Andretti of F1, except Michael Andretti was already the Michael Andretti of F1
MSchu is offline   Reply With Quote
Old 01-29-2010, 05:39 AM   #3
Techno Tonis
2000 Acura Integra
Techno Tonis's Avatar
I found your problem.
Berlina MoB #002
Originally Posted by Chubz
Seriously man, all of us know that you aren't punching anyone in the face. At worst you will be swinging your coach bag and throwing high heels.
Originally Posted by Rude Awakening
I tell her no way. Bust out science on her
Techno Tonis is offline   Reply With Quote
Old 01-29-2010, 05:40 AM   #4
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
No.
How did you bleed them?
How did you compress the calipers?
404: Care not found.
Dogginator is offline   Reply With Quote
Old 01-29-2010, 05:43 AM   #5
oneludesol
oneludesol's Avatar
Send a message via AIM to oneludesol
what were the original "issues"? By "changing the brakes" you mean the pads? If so, why did you bleed the system? If you overfill the res. the only thing that happens is the excess fluid comes out the cap. If you are not getting pedal, and there are no visible leaks anywhere in the system, I would look toward the master cylinder being the issue.
Maserati Coupe GT //EVOMS tuned full Kreissieg Exhaust 459hp-401tq//
Porsche 955 Turbo S //EVOMS ECT600 602hp-617tq//
25%: 2009 GOBOSH 800XP
oneludesol is offline   Reply With Quote
Old 01-29-2010, 05:44 AM   #6
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
I've seen people open the bleeder to more easily compress the caliper.
Old 01-29-2010, 05:46 AM   #7
Cowtit
Cowtit's Avatar
Bled at the bleeders for 3 of the 4 wheels, at the line for the other because the bleeder wouldn't budge and snapped off. Compressed by pumping the pedal, same as I've always done.
- Mark Twain
Old 01-29-2010, 05:49 AM   #8
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
Bleeding at the line will not work.
Old 01-29-2010, 05:51 AM   #9
oneludesol
oneludesol's Avatar
I've seen this too... silly people...
can't bleed from the line...
Old 01-29-2010, 05:52 AM   #10
Cowtit
Cowtit's Avatar
Jettas are a pita...the calipers won't go back in with a c clamp like any other vehicle. I had to take them off and then pound them back in. Gently with a rubber mallet of course....
- Mark Twain
Old 01-29-2010, 05:58 AM   #11
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
Do the pistons rotate to compress?
Old 01-29-2010, 06:03 AM   #12
Cowtit
Cowtit's Avatar
Maybe, idk. I hate this f'n car I'm only fixing it because she hit a deer with my civic.
- Mark Twain
Old 01-29-2010, 06:23 AM   #13
philafelman
philafelman's Avatar
ive done this, and it worked for me. ive bled my clutch at the line when the bleeder snapped off, and also at the master cylinder connections and abs connections.
to OP, im trying to figure out why you needed to bleed at all. maybe if changing pads is this difficult for you, you should take the car in to a professional.
FML
philafelman is offline   Reply With Quote
Old 01-29-2010, 06:37 AM   #14
Cowtit
Cowtit's Avatar
I am mechanically inclined, I always do my own repairs. I just don't have the 20 years of schooling it takes to work on a volkswagen. I've done engine swaps, clutch swaps, water pumps, timing belts and countless brake jobs...... I hate vw's....
- Mark Twain
Old 01-29-2010, 06:39 AM   #15
Archidictus
Unceasing Measure
2011 Chevrolet Cruze
Archidictus's Avatar
https://www.facebook.com/michael.gould.355
Send a message via AIM to Archidictus
My girlfriend has a 2000 Jetta.
I can tell you from personal experience that the rear calipers screw in at a very steep pitch. The fronts are like normal, though the rubber boot sometimes jams up in the groove and makes it more difficult to press the caliper in without tearing it.
It's likely that you destroyed your rear calipers and, thus, the system is never going to work properly again. This is the price you pay for ignorance and frustration when you can go on youtube and get a video step-by-step on how to do it properly -
http://www.youtube.com/watch?v=qrjQofxd-h8
Have fun with the replacements. They're about $140 a piece.
But now the summer's dreams are bent like grain against the scythe, and memories of blissful days, they fall like leaves.
Archidictus is offline   Reply With Quote
Old 01-29-2010, 06:39 AM   #16
philafelman
brakes are pretty universal repairs.
FML
Old 01-29-2010, 06:40 AM   #17
Archidictus
Unceasing Measure
Yup. For a "very mechanically inclined" individual, the OP must not have known that 99% of all rear brake calipers are screw-type.
Old 01-29-2010, 06:41 AM   #18
JDM_Ej
HT Order of Merit
2002 Infiniti G20
JDM_Ej's Avatar
TeamInsane72 JDM_Ej
Send a message via AIM to JDM_Ej
Yea I'm curious what you changed that required you to bleed the brakes...?
Democracy substitutes election by the incompetent many for appointment by the corrupt few. - George Bernard Shaw
JDM_Ej is offline   Reply With Quote
Old 01-29-2010, 06:43 AM   #19
Archidictus
Unceasing Measure
Nothing. He just thought it would be a good idea since you're supposed to do it yearly. Unfortunately, like almost all home brake-bleeds, the system is never as firm as it was stock after you bleed them.
Old 01-29-2010, 06:55 AM   #20
JDM_Ej
HT Order of Merit
2002 Infiniti G20
JDM_Ej's Avatar
TeamInsane72 JDM_Ej
Yea I had to replace a brake line on my Civic a few years ago... no matter how I bled manually, it never was the same.
Old 01-29-2010, 06:59 AM   #21
Cowtit
Cowtit's Avatar
Well than very popular chevy trailblazer must be in the 1% because I just changed those last month and guess what? Not a screw in .
- Mark Twain
Old 01-29-2010, 07:03 AM   #22
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
It all depends on the parking brake. My 2005 Odyssey has seperate brake shoes for the parking brake and a normal caliper in the rear.
Old 01-29-2010, 07:06 AM   #23
Stroker
Guest
Posts: n/a
So did you screw them in or not.
Old 01-29-2010, 07:10 AM   #24
Cowtit
Cowtit's Avatar
No, they push back in with c clamp.
- Mark Twain
Old 01-29-2010, 07:10 AM   #25
89efDUSTY
2006 Ascari A10
89efDUSTY's Avatar
iTrader Rating: (4)
Really? I do this for almost all my friends when I change their brakes, just to clean out some nasty fluid. Every single one of them has had a firmer feel afterward. Maybe this is because I am not doing that self bleeding BS...helper on the pedal FTW!
89efDUSTY is offline   Reply With Quote
2001, bleed, bleeding, brake, car, clutch, cylinder, filled, fluid, jetta, master, nsx, overfill, overfilled, overfilling, problem, problems, self
