why is my Vtech cutting out!?
Old 01-22-2010, 10:17 PM
Prelude 4 life's Avatar
Default why is my Vtech cutting out!?
I just put an H22a DOCH Vtech in my 92 honda prelude si 4ws. when i first put the motor in my Vtech hit just fine now when i hit Vtech it boggs out but still engages!??
Any ideas why?? Thanks!
Old 01-22-2010, 10:21 PM
daymkimchee's Avatar
Default Re: why is my Vtech cutting out!?
my h22 swap did the exact same thing.My issue was the fuel.First my fuel filter was clogged up i changed that.fixed the problem for 2 months and then it did it again .Found out i had a rusted gas tank.Just Check all your basics like ignition and fuel
Old 01-22-2010, 10:47 PM
nebraskaimport's Avatar
it does sound like fuel filter not flowing enough at higher rpm's. what do you have your vtec set at?
Old 01-23-2010, 08:23 AM
KreLude's Avatar
Becuz u can't speel it rite?
Old 01-23-2010, 09:38 AM
soto2635's Avatar
yup deff check that fuel filter
Old 01-23-2010, 12:45 PM
Ya did that already. i put new sparks and wires along with the fuel filter.
Old 01-23-2010, 12:46 PM
um it kicks in at 5
Old 01-23-2010, 01:54 PM
ben_deez's Avatar
tell me if this sounds familiar... your driving and then you punch it and then hit vtec.... then all of a sudden the car feels like something has cut the fuel off (kind of like the speed limiter cutting you off at a certain point?) did this happen at WOT (wide open throttle), and are you running a stock p13.....
if this sounds like you............ I got some answers
Old 01-23-2010, 07:37 PM
Ya thats what it's doing! it drives fine then i punch it and hit Vtech and it cuts out! ya i think i am running a stoke p13??
Old 01-23-2010, 07:51 PM
MiG-21 superfan
builthatch's Avatar
let me interrupt for a second to clear something up-
wrong=Vtech
right=VTEC
Variable Valve Timing and Lift Electronic Control
wrong= DOCH
right= DOHC
dual overhead cam
Old 01-23-2010, 08:00 PM
Um ya i can my bad i didnt capitalize VTECH! You are the one with spelling problems! you cant even spell "spell" or "right" so shut your mouth!
Old 01-23-2010, 08:22 PM
nus_dogg's Avatar
Weird. I thought it was a fuel filter too but you already said its been replaced.
Old 01-23-2010, 08:46 PM
BDM
BDM's Avatar
My VTEC is intermittent. If it does engage it never cuts off halfway through or anything. It engages most times but not everytime. I've read that it could be a dent in the oilpan. I have a few little dents in it. I'm going to see if replacing the oil pan fixes the problem.
How often should the fuel filter be changed? Is there a way to check to see if its time to replace it? I don't know if any of the previous owners ever replaced it. Car is at 270,000 miles and fueling a JDM H22.
Old 01-23-2010, 09:12 PM
tempban's Avatar
this guy's a dumb ***
Old 01-24-2010, 07:01 AM
ben_deez's Avatar
I've only had it cut out like that once..... right before I put a chipped ecu in..... needless to say, the problem was no more.......
but that don't help you out at all......
if the fuel, spark, and intake, etc. are all good, then I would start looking at the knock sensor, vtec pressure switch, making sure your CEL bulb is good..
then look at the MAP, and TPS for cross-plugging......
to me it was more like a switch being thrown, the cut off was that quick.... maybe your vtec pressure switch lost pressure.....
or just get a chipped ecu.... you have a 4 wheel steering ecu also.... did that come with the car or the motor
one more thing.... is oil leaking from your vtec solenoid...
Old 01-24-2010, 07:10 AM
ben_deez's Avatar
Originally Posted by [B
tempban[/b];41342624]this guy's a dumb ***
....."Tampon".... are you telling me you didn't see the fact that your name is basically "Tampon"....thats funny ****
a monkey with a blind fold, hanging from his tail could of seen that
Old 01-24-2010, 07:33 AM
MiG-21 superfan
builthatch's Avatar
has nothing to do with capitalization and everything to do with being accurate on a technical forum- namely, it has to do with you adding an "H" to VTEC. there is no "H", unless you are talking about the company that manufacturers consumer electronics, Vtech.
http://www.vtech.com/
you are welcome for my correction. i am helping you, yet you criticize me. and on top of that you tell me, a moderator, to "shut my mouth".
watch your attitude.
Old 01-24-2010, 07:59 AM
Geoff92's Avatar
owned.
on a side note, i dont think there is really a way of "checking" your fuel filter, but its cheap enough just replace it and see if it helps, if it doesn't. atleast you have a clean fuel filter
Old 01-24-2010, 09:36 AM
Originally Posted by Geoff92
owned.
Ya thats true there only seven dollars, but on the other hand i just replaced it like a week ago?!
Old 01-24-2010, 09:44 AM
Oh really!... Yeah ill have to check that! i dont belive its leaking oil?? Where is the switch actullay located? No my car came with one its located behind the back seat. i can hear it turn on when i turn the key over.
Old 01-24-2010, 11:03 AM
Oh no hey thats my bad that was not suppose to be directed toward you! I clicked on the wrong Qoute! So my bad! Yeah i seen that i put an "H" on VTEC i was thinking of taking to honda at the same as i was writing this! So my bad i apologize!
Old 01-24-2010, 12:22 PM
tempban's Avatar
you should know you have a whole box in your ***
Old 01-24-2010, 12:31 PM
99r
99r's Avatar
Wow noobs with 8 posts shouldn't be allowed to start topics.
hahaha this amazes me.
Hey ill give you 100,000 for your DOCH VTECH motor man. Can you do 100,000 shipped?
Old 01-24-2010, 01:16 PM
LOrangeH22hatch's Avatar
Are you throwing any codes?
What about oil pressure?
Could be engaging vtec and then falling out of vtec due to lack of oil pressure.
Just a thought.
Old 01-24-2010, 02:25 PM
Bay_Sick_Vizion's Avatar
Just a thought.
How do i check the oil pressure, im not throwing any codes so im stumped. same problem just Sohc.
Quick Reply: why is my Vtech cutting out!?
