Go Back   Honda-Tech > Honda and Acura Technical Forums > Lighting
Old 01-13-2010, 03:04 PM   #1
KraZyCHOWMEIN
KraZyCHOWMEIN's Avatar
Send a message via ICQ to KraZyCHOWMEIN Send a message via AIM to KraZyCHOWMEIN
Default Want to slow down my turn signals
I just changed my turn signal bulbs to LED bulbs because they are brighter.... well now I have high speed flashers. Loved them in 2001 but I am looking for a solution without having to cut the harness to get my turn signals back to a normal flashing rate.
Anyone have a solution to my problem?
Thanks for your help!
Hindsight is always 20/20
KraZyCHOWMEIN is offline   Reply With Quote
Old 01-13-2010, 03:09 PM   #2
KraZyCHOWMEIN
Default Re: Want to slow down my turn signals
http://www.customled.com/products/lo..._equalizer.htm found this, has anyone used this? Is there an alternative to this?
Thanks!
Old 01-13-2010, 04:02 PM   #3
TunerN00b
TunerN00b's Avatar
Thanks!
The alternative is to change the resistor in the flasher unit itself. Using a potentiometer instead of a static resistor will allow you to adjust it as well.
TunerN00b is offline   Reply With Quote
Old 01-14-2010, 07:29 AM   #4
KraZyCHOWMEIN
Thanks TunerN00b. What are the specs on the resistor that I need to change and how involved is it to change this?
Thanks!
Old 01-14-2010, 11:30 AM   #5
TunerN00b
TunerN00b's Avatar
Thanks!
You solder new wire leads on both sides of the existing resistor. Use a multimeter to find the current resistance value, and know that you'll have two in parallel if you don't remove the existing one. Base the pot value off of that.
If that is too "electrical engineer" for you, then this mod might be best skipped. In which case, look for a plug in box to allow normal flashing rate with LEDs. These are readily available.
That said, I've never seen an LED that was actually brighter than halogen bulb for turn signals. Many claim to be, but none seem to actually be.
Old 01-17-2010, 05:58 AM   #6
Hawkze_2.3
Hawkze_2.3's Avatar
I'll second that! LED bulbs are only beneficial because they use less power and can turn on/off instantly for quicker visual response, but they are definitely not any brighter. If anything, they are dimmer....
To fix the fast blinking I personally always solder in resistors made for LED bulbs into the OEM wiring. They are all over eBay (VLEDS and HyperLEDs always have fast shipping and great service).
'95 Prelude--intake, windshield washer lights, rear body kit, carbon fiber windows. '86 Mazda RX7--Chevy & Borg-Warner powered. '99 Honda CRV--Jurassic Park tour vehicle. '98 Chevy Lumina--what is that thing?
Hawkze_2.3 is offline   Reply With Quote
Old 01-18-2010, 04:52 AM   #7
DA9_DAD
1990 Acura Integra
DA9_DAD's Avatar
iTrader Rating: (4)
auto zone sells the resistors for cheap. They have a long white rectangular piece with 2 black wires at each end. Used them and they work well when I converted to LED.
DA Squad Member #3
WWW.G2IC.com Exclusively for the DA and DB enthusiast.
DA9_DAD is offline   Reply With Quote
add, blinker, fast, flasher, flashes, led, location, prelude, r6, resistor, s2000, signal, slow, slower, turn
