D15b O2 sensor
Old 01-12-2010, 10:55 AM
pedrolucas's Avatar
Default D15b O2 sensor
Ok new problem today, Two wire out of 4 broke on my o2 sensor. Check engine light is off but the car smells like gas and my exhaust is completely black inside.
Spec :
95 D15b
OBD1
The only thing I can guess is that there is no ''heat sensor'' on OBD1 engine and my broken wires are these one.
Can i run like this ?
Old 01-12-2010, 11:14 AM
shoklid's Avatar
Default Re: D15b O2 sensor
fix the wires ! its goin to run rich without o2 thats why it smells like gas and has unburned fuel in you're tail pipe
Old 01-12-2010, 11:32 AM
pedrolucas's Avatar
Ok thanks, but now I need to know wich O2 sensor I need. I cannot ask for jdm d15b O2 sensor at my shop. I guess it is D16Z6 ?
Old 01-12-2010, 11:45 AM
shoklid's Avatar
umm o2 sensors are pretty much universal just make sure u got the 4 wires right. and also jdm dont mean **** when buying anypart from a part store. just tell them u have a 95 civic 1.5 liter and it will come up they did make 1.5 in the usa
Old 01-12-2010, 11:55 AM
thumper64's Avatar
Get whatever 02 sensor is for your ECU. If you use a Z6 ECU, get one for a Z6 (the 4 wire). There are universal fit ones on eBay for a decent price, just make sure you get a Denso or something. The P08 the D15B originally ran on used a 1 wire sensor...
A lot of people neglect to change their O2 on time and it can get lazy as it wears out. How old is yours....?
Old 01-12-2010, 03:22 PM
pedrolucas's Avatar
I changed it now it seems to be good ! Thanks for everything !
Old 01-31-2010, 11:08 AM
nothing_shocking's Avatar
What ecu and o2 sensor are you using? I've pretty sure I saw that you can use the 4 wire o2 with the p08 with no problems.
1993eghatch
09-24-2010 05:52 PM
ken2830
02-01-2008 12:09 AM
EF9ZC
03-28-2006 10:48 AM
victoriasamantha
06-01-2004 08:08 AM
SIckH22Atch
05-08-2003 09:49 AM
Quick Reply: D15b O2 sensor
