| Welcome to Honda-Tech! | ||
#1 |
I am trying to troubleshoot a no-start 1997 Civic CX (D16Y7). I'm thinking it might be an ignition issue so I'm going through the ICM input test per the factory service manual. It states:
"Disconnect the ECM/PCM connector A (32P)." Where is this thing? Any other troubleshooting clues would also be appreciated. So far I've tested the basic four components (fuel, spark, compression and timing). They all seem to exist but are probably not in the amounts needed to start the pup. ![]() Thanks! |
#2 |
passenger side kick panel under the glove box
***ANTI-HEROS president*** Trailer wheels on Hondas makes baby Jesus cry FS Rare volk le37 http://forums.nwp4life.com/zerothread?id=41741 |
#3 |
yes sir thats where it is just like any 92-00
95 civic sedan |
#4 |
Got it, thanks!
#5 |
1996 Honda CivicMy Garage |
do you have a tach ? if you do and it doesn't move when cranking your igniter is more than likely bad. Have you checked for code's ??
if speed kill's do brakes give life? |
#6 |
I did replace the ICM but there was no change. The spark is definitely yellow/orange, is that a definitive symptom?
| Tags |
| 1997, 2005, 97, accord, box, civic, connector, ecm, ecmpcm, honda, location, odyssey, pcm, prelude, troubleshooting |
