Old 01-06-2010, 09:18 PM   #1
civic90242
Default where is the 1994 civic diagnostic port.
i dont know where it is at
does anyone know where it is at?
civic90242 is offline   Reply With Quote
Old 01-06-2010, 09:20 PM   #2
vtechjunkie
vtechjunkie's Avatar
iTrader Rating: (2)
Default Re: where is the 1994 civic diagnostic port.
Under the dash, on the passenger side of the car. If it hasn't been tampered with it will have a green sleeve over it. Otherwise, it is a brown two wire plug.
My vouches
http://www.hondamarketplace.com/show....php?t=2669009
HID retrofit club member #0059
vtechjunkie is offline   Reply With Quote
Old 01-06-2010, 09:32 PM   #3
civic90242
and im new to this honda stuff. so is the port a obd2 or obd2?
Old 01-06-2010, 09:35 PM   #4
EL Vap133
Moderator
EL Vap133's Avatar
Send a message via AIM to EL Vap133
Huh? obd2 or obd2 you ask?
IIRC, the 94 Civic should be an obd1.
EL Vap133 is offline   Reply With Quote
Old 01-06-2010, 09:38 PM   #5
civic90242
my mistake, my bad
ok thank you i thought it was a obd2
Old 01-06-2010, 09:41 PM   #6
vtechjunkie
iTrader Rating: (2)
Just connect the two ports with the key in "on" position, and the check engine light will flash. Long flash is 10 and short is 1.
My vouches
Old 01-06-2010, 09:45 PM   #7
civic90242
ok thanks bro
Old 01-06-2010, 09:50 PM   #8
darkenedsol
1994 Honda Del Sol
My Garage
darkenedsol's Avatar
Okay-since no one brought this up,
Pre-1996= OBD 1 Datalink under pass dash-
1996-Present= OBD 2 16-pin Dataport under driver-side dash under steering wheel
OBD= On Board Diagnostic
1= 1 O2 sensor per engine bank, used for ECU fuel trim/compensation
2= 2 O2 sensor per engine bank, 1 upstream before catalytic converter (cat), 1 downstream after catalytic converter (cat) downstream used for ECU monitoring of catalytic converter efficiency.
Hope this helps!
darkenedsol is offline   Reply With Quote
Old 01-06-2010, 09:52 PM   #9
civic90242
Hope this helps!
really good info, thanks
Old 01-06-2010, 09:54 PM   #10
darkenedsol
1994 Honda Del Sol
My Garage
Oh, and for clarification, to decipher the code for the check engine light, you can plug a paper clip into the datalink connector on the pass side of the car, and count the flashes with the key on, engine off. the long flash indicates the first number, and the short flash indicates the second number. Ex., two long flashes, two short flashes equals code 22. Good luck!!!
1990, 1994, 1996, 2001, 94, accord, acura, civic, connector, diagnostic, honda, integra, location, obd, plug, port
