Old 01-02-2010, 06:59 AM   #1
Pele
Pele's Avatar
Send a message via AIM to Pele
Default 1996 Civic DX Hatch (Automatic Transmission) Shifting improperly
I've got a 1996 DX Hatchback with an automatic transmission that's shifting really sluggishly.
The car is 100% stock. D16Y7 engine, 4 speed automatic.
It's not slipping in any way, but a lot of times when I press the throttle, it takes a couple seconds to downshift.
Sometimes when starting from a dead stop (IE Stop sign or red light), it almost feels like a neutral drop.
It's the same way on upshift when I let up on the throttle (IE I'm on the highway and I do not need to accelerate any more), the upshift takes a few seconds and it'll actually be engine braking for a second or two before it upshifts.
I'd normally assume that this would be a loose kickdown cable that goes from the throttle to the transmission. I could not find this cable on the car.
Then I thought it my be a vacuum modulator that uses engine vacuum to determine when to shift. I could not find any vacuum lines from the engine to the transmission.
This brings me to one major question, how does the automatic transmission know when to shift?! There has to be some connection between the engine and transmission aside from the torque converter to flexplate.
1996 Honda Civic DX Hatch Failomatic - Mom's Car
1996 Honda Passport EX 4WD - Daily Driver
Pele is offline   Reply With Quote
Old 01-02-2010, 07:15 AM   #2
Snap-off
Default Re: 1996 Civic DX Hatch (Automatic Transmission) Shifting improperly
I'm not surprise, honda makes horrible automatic transmissions. I know I have replaced over a hundred atleast, you see the V6's crap out more often though. They had a recall for the V6's, whether it's accord's or Tl's, almost all the same. Do you have any Cels up? I would definately start from there.
Snap-off is offline   Reply With Quote
Old 01-02-2010, 09:42 PM   #3
Pele
Pele's Avatar
Only CEL was for PO171 "Bank 1 too lean". I cleared it and it's stayed clear for a week now, so I assume it was a fluke.
Old 01-02-2010, 10:59 PM   #4
Ruben19
Ruben19's Avatar
Send a message via ICQ to Ruben19 Send a message via AIM to Ruben19
time for a new tranny
Middle finger to All Thieves here in WA and over the world, they deserve to die now
Em1 crew Peyton Manning #18 Best QB in the NFL. I <3 HATERS
Ruben19 is offline   Reply With Quote
Old 01-03-2010, 02:42 AM   #5
Snap-off
well the automatic transmission is complicated, that's why most people just replace them to save them the hassle. i know there are pressure switches and what not that communicate with the ecu, i'm sure there are more things, more variables, that communicate with ecu telling the trans when to shift but your guess is as good as mine if you don't have any CELS. If the trans is slipping, you probably will just need a new one.
Old 01-03-2010, 04:01 AM   #6
94EG8
Honda-Tech gave me this lousy title
94EG8's Avatar
The ECU gets signals from the input shaft sensor, countershaft sensor, TPS and few other things IIRC and determines when to shift based on this.
"Bacon tendercrisp chicken, the most powerful sandwich in its class."
Per ardua ad astra
My F/S thread -> http://hondamarketplace.com/showthread.php?t=2900962
Originally Posted by Knightsport View Post
Hello,
This is Knightsport, from the internet. I will be out of the internet from June 2 and returning on June 11th. In my absence I suggest you pray as there can be only one Knightsport from the internet.
Thank you and God Bless,
-Knightsport
94EG8 is offline   Reply With Quote
Old 01-04-2010, 06:51 AM   #7
Pele
Pele's Avatar
Crap. I knew I shoulda kept that EG sedan and just replaced the front end.
I hate automatic transmissions.
Old 01-04-2010, 08:16 AM   #8
aaron5627
TRIAL USER
Do a google search for the service manual. Look in the drive-train section and you should find a trouble shooting guide. From the research I have done I believe it may be your linear solenoid; I have a 99' LX with the exact same problem. I replaced a broken motor mount in hopes of fixing the problem, no luck unfortunately.
I just flushed my transmission (always use honda ATF) and I plan to clean the linear solenoid and install an axillary transmission filter this weekend; my trans shifts much smoother now but it still has a harsh downshift. I believe the transmission only has one filter inside the case that can only be changed by opening up the trans. The solenoids are really sensitive to debris such as clutch and friction disk wear. I am hoping the aux transmission filter will significantly reduce debris in the trans. fluid and increase reliability.
A guy with an Acura TL on another forum had the same problem as you and me, he removed, clean and reinstalled his linear solenoid and harsh shifting disappeared.
I am hoping that I am right on my conclusions. If I get to it before you I'll post again.
I hope this will help.
aaron5627 is offline   Reply With Quote
Old 01-04-2010, 01:38 PM   #9
94EG8
94EG8's Avatar
Its pretty simple to swap in a manual. Especially on a '96 - '00.
Per ardua ad astra
Hello,
-Knightsport
Old 03-10-2010, 07:36 PM   #10
ChevelleSSLS6
ChevelleSSLS6's Avatar
dump the slushbox
His: 04 Subaru Impreza 2.5 5-spd *too much fun in snow*
Hers: 07 Saturn Vue *3.5 Honda v6 underhood*
ChevelleSSLS6 is offline   Reply With Quote
Old 03-10-2010, 07:39 PM   #11
itsnotfast
1997 Honda Civic
itsnotfast's Avatar
Send a message via AIM to itsnotfast
I recoment the auto to manual. I did it in my 97, it wasn't to bad. I have the auto trans out of my EX, if you want it let me know.
99 EJ8 07 GSXR600-Sold 96 Tahoe
Originally Posted by B16acivicsedan91 View Post
If its just the JDM look your going for you can always overnight nuts and bolt from a JDM home depot lol
itsnotfast is offline   Reply With Quote
Old 03-11-2010, 04:47 AM   #12
aaron5627
TRIAL USER
I may be interested in your auto trans. Any idea how much it would cost to ship it to Jacksonville, Florida?
Old 03-16-2010, 06:54 AM   #13
titi_vtec
titi_vtec's Avatar
Send a message via MSN to titi_vtec
hey friend what you can do is remplace the oil with atf zr1 that is the genuine honda atf, and put a half of lucas oil for transmition on it, and every 30.000 milles doit again if you want continuos with that transmition if you want to fix it just clean the valvle box that it has but you has to make a hard work for do that
titi_vtec is offline   Reply With Quote
Old 03-23-2010, 01:15 PM   #14
aaron5627
TRIAL USER
Ok, so I finally got around to looking at my transmission... I was wrong about the Linear solenoid, it ended up being the shift solenoid. To check the solenoid all you need to do is unplug them from the engine harness and check their resistance with an ohm-meter. Here are the specs.
Lock-up solenoid: 5-25ohm
Shift solenoid: 5-25ohm
Linear solenoid: approx. 5 ohm
My Linear Solenoid was at 5.4ohm and my shift solenoid was at 28.x ohm. I ordered the part from O'reilly's w/ a lifetime warranty for $138!!! on the higher side of the normal price but when it fails I get a new one for free!!! yea baby!
Old 03-23-2010, 01:18 PM   #15
aaron5627
TRIAL USER
Oh yea, those specs are for the 99' LX w/ a D16Y7 engine. Check the for yours in the shop manual.
Old 05-19-2012, 07:10 AM   #16
fil
I have the same problem with my 96 ex automatic, wont shift sometimes would just stay in 1st gear, then sometimes it would shift, need to warm it up, cleaned at fluid change, but still the same honda dealership rob my wallet for the fix they did but never fixed, need help on probably converting it to manual tnx
fil is offline   Reply With Quote
1996, 2000, accord, auto, automatic, cable, civic, dx, honda, linkage, located, shifter, throttle, trans, transmission, warranty
