Change your power steering fluid!
Old 09-25-2012, 02:57 PM
  #26
SirProject's Avatar
Default Re: Change your power steering fluid!
and idk what fluid you used but if it wasnt honda i dont understand why. you can buy the stuff for $5 a piece from honda or find it on ebay real cheap
Old 09-25-2012, 04:29 PM
  #27
PreClude's Avatar
At the same, I thought PS was PS, regardless of brand. I mean, I knew I had to get "Honda specs", but didn't think I actually NEEDED the OEM Honda brand fluid. Never had that problem on any car I've ever owned in the past. But now I understand and I read lots of stuff about people having failures because of not using the OEM fluid. You're right, it's cheap. I have 3 bottles of it sitting in front of me now, I just have to figure out this leak before I go emptying and refilling the reservoir for no reason.
Old 09-25-2012, 04:32 PM
  #28
Plead da Fif
It Wasn't Me's Avatar
Originally Posted by PreClude
The bottle I used said it was "for Honda/Acura" but I have my doubts only because of my now apparent leak/failure (?) but it could just be coincidence. Still trying to figure this one out:
How old is the pump? How many miles are on it? Is it leaking from the pump itself, or a line? It LOOKS like it's from the pump...
You're in the wrong forum, by the way. That's not a Civic power steering pump.
As noted earlier; I've been using the same non-Honda brand (MasterPro) power steering fluid for well-over two years without any problems whatsoever.
Old 09-25-2012, 08:30 PM
  #29
PreClude's Avatar
I know, wrong forum, sorry. I'm going to try getting a gasket/seal kit/set for my PS pump assembly thingy and see if it was just those going bad. And yes, I will be using Honda OEM fluid from now on.
mimog3
04-28-2013 11:38 PM
tt3
10-06-2011 04:43 PM
old_school_dohcvtec
01-18-2006 03:23 AM
arsenal22046
12-17-2004 02:29 PM
tintin11
08-05-2003 03:15 PM
Quick Reply: Change your power steering fluid!
