Rich Porter Distributors, good or bad
Old 12-29-2009, 04:12 AM
OH_1fstgsr's Avatar
Default Rich Porter Distributors, good or bad
Does anyone have any personal experience with these Distributors? Good or bad.
http://www.richporter.ca/ there web site is not very helpful.
My stock distributor has a bearing going bad. I have a 135,000 miles on the car.
Was looking for some thing other than stock. New OEM is about $300 dollars.
King Motorsports carries them.
http://www.kingmotorsports.com/category.aspx?cat=103
Old 01-01-2010, 05:02 AM
OH_1fstgsr's Avatar
Default Re: Rich Porter Distributors, good or bad
Has anyone heard of these?
Come on Canadian brethren they are from Canada. Someone must be using these.
I can’t tell if this is good news or bad news that no one has any kind of experience with these distributors.
Old 01-01-2010, 05:09 AM
All Motor Mentor
00Red_SiR's Avatar
They are good, they're based out of Montreal I believe. I'm using one of their distributors now on my car with no issues at all.
Old 01-01-2010, 05:13 AM
OH_1fstgsr's Avatar
How many kilometers(miles) on it? And which one, High Performance or Replacement?
Old 01-01-2010, 05:15 AM
All Motor Mentor
00Red_SiR's Avatar
about 2 years or 20,000 kms on it and I got the high performance one.
Old 01-01-2010, 06:25 AM
dester223's Avatar
They are good distributors. They use new components. But as with every electrical part that we have used, I see failures from time to time.
Overall, their failure rate is VERY low. I think we've had 3 distributors go "bad" over the last 4 years.
1) the shaft seal started to leak. Changed with an OEM honda seal = no more problems
2) one distributor on a OBD1 ZC engine started making the car run weird. I got a new one warrantied and no more issues
3) I don't think it's a major problem, but on a couple OBD1 honda distributors, the 2 wire plug rubber inside the clip is a little fat, so you have to take the one from your old distributor and move it over, otherwise it's almost impossible to clip the distributor clip on.
Old 01-01-2010, 10:11 AM
OH_1fstgsr's Avatar
Why did you got this route over OEM?
Nearly $600 or $300 OEM.
Thanks for the information. Exactly what I was looking for.
Old 01-01-2010, 01:21 PM
All Motor Mentor
00Red_SiR's Avatar
I got mine quite a bit cheaper than the $600 as I use to own a local performance shop and was able to source one for less through some old business contacts I had.
Old 01-02-2010, 03:47 AM
OH_1fstgsr's Avatar
That makes sense.
Thanks for all your help. I will order an OEM on Monday. It should make it another 100,000 on my car.
Old 08-25-2010, 03:37 PM
vw1
vw1's Avatar
Icon3 Re: Rich Porter Distributors, good or bad
Hey, finally someone has asked about these distributors. Most people don't know I guess. Any way, I bought one for a 71 vw. Had piontless ignition and ball bearing, bearings. Worked like a champ, primo, excellent! 127.00 at bap geon auto parts. cheap price. O.K. also bought one for a 97 chevy 4.3 with a bad gear, worked like new, checker wanted 203.00 jeez! got on on amazon for 80.00 These look and feel like good solid units.
Old 02-05-2012, 08:39 PM
honda_lx's Avatar
Thanks for the website link.
I wish I would have found this before I bought mine from the local O'reilly's. could have saved 50 bucks :/
fastcrxsi90
10-30-2002 02:31 PM
Quick Reply: Rich Porter Distributors, good or bad
