leaking water from under?
my accord leaks water every time i turn on the fan or the heater. the water leaks even when i dont use the AC. is something wrong with my car?
In a Junkyard near you.
Re: leaking water from under?
Ahh still a clogged drain tube then. Even though the a/c isn't turned on the compressor still runs on defrost settings and is removing humidity from the air.
So if you clean the drain tube you should get a nice bath and fix the problem.
