Classic Hondas All Pre-1988 Hondas.
86 Honda Accord
Old 12-20-2009, 07:17 PM
FrankBHonda's Avatar
Default 86 Honda Accord
I have an 86 Honda Accord (Carburated-Automatic). I start the car by hitting the gas once and then start. It goes to 2200 RPM's and then after a moment or two I kick it down to 1500 where I put it into Drive and go. Is there an adjustment I can make that will adjust both above RPM's down as I am afraid
I am going to hurt the trans by putting it into gear at 1500.
Thank you very much for your help!
Old 12-20-2009, 08:41 PM
2DrSE-i's Avatar
Default Re: 86 Honda Accord
No experience at all with the carbed accords. 3geez.com is your friend!!
Old 12-20-2009, 11:59 PM
2ndGenGuy's Avatar
Your car is running how it should. It is supposed to run about 1500RPM until the engine warms up a bit. It won't hurt it to kick it into drive like that. It does eventually settle down to ~750RPM or so, doesn't it after it warms up?
Old 12-21-2009, 07:58 AM
Thank you for the response.
Yes it does settle down after driving for a few minutes to a lower very smooth RPM around 750. So it doesnt hurt the trans to place in gear at the high RPM?.
This is a very nice shape 86 Honda we just bought for my daughter and it runs and looks great. It looks as though it has a pretty new trans.
Old 12-21-2009, 09:30 AM
2ndGenGuy's Avatar
Nope, sounds like it's running great. Just as it should! No worries about putting it in gear at high idle. It was designed to do it.
Old 12-21-2009, 01:20 PM
Thanks. Are there PCV valves on these?
Old 12-21-2009, 02:49 PM
2ndGenGuy's Avatar
Yes, I believe on the 3rd gen it's on the intake manifold. If I remember right (been a while since I worked on a 3rd gen) it's in between runners 2 and 3.
Old 01-06-2010, 05:13 PM
rxbahamut's Avatar
It might help out if you let it run for about 5 minutes before you go. I always let my car run for a small amount of time before I go when it is cold, but it will not hurt it to just start it and go.
FAMICOMASTER
Classic Hondas
08-19-2018 05:53 PM
williaac
10-24-2016 07:16 AM
Chin Zimbabwe
12-16-2013 06:03 AM
kinghypnotic203
10-21-2010 04:07 PM
FrankBHonda
Engine Management and Tuning
09-06-2009 09:16 AM
Quick Reply: 86 Honda Accord
