Temp gauge not working...
Old 12-19-2009, 06:59 AM
undrh2o's Avatar
Default Temp gauge not working...
Did a search with limited results...
my '95 Civic Dx temp gauge does not work and the local parts houses cant tell me which sensor I may need to replace...
the water temp sensor or air temp?
any help would be much appreciated ~
TIA
Old 12-19-2009, 07:02 AM
Matt93eg's Avatar
Default Re: Temp gauge not working...
Look on the cylinder head under the Distributor, you will see a sensor going into the head, its a 1-wire. This sensor gives feedback to the temp gauge on your gauge cluster. I have seen the connectors break off the sensor where it hooks on.
Old 12-19-2009, 07:04 AM
undrh2o's Avatar
Thanks Matt, will look at that and see!
Old 12-19-2009, 07:24 AM
Matt93eg's Avatar
No problem, hopefully its something simple like that. Also found this for you.
Old 12-19-2009, 07:31 AM
undrh2o's Avatar
Thanks for the help! Especially the diagrams!!
I'm heading your way tomorrow to look at some wheels/tires, will be glad to buy you lunch for the help!!
Thanks again ~
Old 12-19-2009, 07:34 AM
Matt93eg's Avatar
Nah you ain't gotta do that man, just glad I could help. Where you buying wheels/tires from?
Old 12-19-2009, 07:36 AM
undrh2o's Avatar
Ad I found online for some Drag DR 23's, just says Concord...gonna get an address shortly and head that way in the morning.
Old 12-19-2009, 07:45 AM
Matt93eg's Avatar
Sweet, good luck with your purchase, hope it works out.
Old 12-19-2009, 07:55 AM
undrh2o's Avatar
If I end up buying I will post pics for everyones viewing pleasure...
Old 12-19-2009, 08:01 AM
Matt93eg's Avatar
Most of us like pictures.
Old 12-19-2009, 11:51 AM
Corksil's Avatar
in my experience that temp sender under the distro can become cooked and brittle from the motor heating up over time and break off quite easily.
Old 12-26-2009, 06:12 PM
undrh2o's Avatar
already replaced the temp sending unit...did not fix problem
Old 12-26-2009, 08:33 PM
Mr. Badwrench
boostedcivicsir's Avatar
hows your heat? is it warm but not as warm as it should be? how cold is where you are?
im asking the condition of the t stat.
Old 12-26-2009, 09:28 PM
Former User's Avatar
Also check the coolant level in both the radiator and reservoir.
Old 12-29-2009, 02:05 PM
undrh2o's Avatar
Coolant level is good in both...looks like the gauge so I'm looking now for a new cluster, maybe one with tach.
thanks for the suggestions!
Old 01-13-2010, 12:48 PM
undrh2o's Avatar
Ok...
replaced my cluster with another from an LX and still have the same "no temp gauge" issue...
I have checked the #15 - 10 amp fuse, replaced the sending unit and now the cluster with the same result...actually looks like the temp needle drops when the key is on.
any more ideas?
TIA
Old 01-13-2010, 12:51 PM
Did you ever do any of the tests in the posted diagram. Guessing solutions at random can get very expensive.
Old 01-13-2010, 01:00 PM
undrh2o's Avatar
I did the testing, thats why I replaced the sending unit first...when that didn't work I replaced the cluster (wanted a tach anyway)
Old 01-13-2010, 01:05 PM
What was the result of the Sending Unit Test and Gauge Test prior to replacing either component versus now. I presume that your test results then and now do not fit with either being the problem. Instead, it sounds like a bad wire or connector between the sending unit and cluster.
Old 01-13-2010, 01:08 PM
undrh2o's Avatar
grounding the sending unit wire resulted in no movement of the gauge when ignition switched on
impedence reading of unit itself was off a little but no it didn't indicate as being bad but I replaced it anyway...
I visually inspected the wire as far as possible without tearing into the harness and didn't see any break
Old 01-13-2010, 01:16 PM
Very good, but I think you mean resistance here.
Very good.
Here's where you went wrong and didn't follow the instructions in the diagram. You usually can't tell visually whether a wire is bad. You need to use your multimeter to test for lack of continuity between the ends at the sending unit and cluster.
Old 06-26-2013, 06:41 AM
roberts si's Avatar
I have the same problem with my temp gauge, cantseem to figure mine out either
Old 06-26-2013, 06:43 AM
Ryan Lwin's Avatar
Make new thread with more details.
Old 07-01-2013, 06:01 AM
roberts si's Avatar
Got it working, turned out to be a bad connector on the wire that plugs into the sensor
Old 07-27-2019, 11:17 PM
Odabirra Jhay's Avatar
temp. Guage not working i cannot locate the wiring
Quick Reply: Temp gauge not working...
