Old 12-13-2009, 05:13 PM   #1
GSR936
Send a message via Yahoo to GSR936
Default putting ac into a 98 ek coupe gsr swap
what do i need to put ac into a 98 civic ek coupe that has a gsr swap ?
GSR936 is offline   Reply With Quote
Old 12-13-2009, 05:16 PM   #2
Anon51
Anon51's Avatar
Default Re: putting ac into a 98 ek coupe gsr swap
do you have your original a/c lines? no lines? evaporator? condenser? dryer? compressor?
Anon51 is offline   Reply With Quote
Old 12-13-2009, 05:18 PM   #3
GSR936
car has lines but no ac compressor or condenser
Old 12-13-2009, 05:42 PM   #4
GSR936
ttt
Old 12-13-2009, 06:06 PM   #5
Anon51
Anon51's Avatar
do you still have the gsr a/c bracket bolted on? if not go grab a vtec delsol a/c bracket or its much cheaper counter part the crv b20 a/c bracket. and find a 96-98 d series a/c compressor. unless you wanna use a gsr a/c compressor in which case a gsr bracket and compressor and lines is what you want.
Old 12-13-2009, 06:24 PM   #6
GSR936
OK i found a b20 ac bracket for 30 bucks. can i use a 97 auto d series ac comperssor?
Old 12-13-2009, 06:24 PM   #7
GSR936
and condenser from a 97 auto?
Old 12-13-2009, 07:00 PM   #8
Anon51
Anon51's Avatar
yea you just need teh d series compressor lines now that go from the evaporator to the compressor and condensor.
Old 12-14-2009, 06:06 AM   #9
GSR936
alright just making sure the ac compressor and condensor were from a 97 civic auto were the same.
Old 12-14-2009, 06:19 AM   #10
Vindicator9000
318 Curves, 11 miles
2000 Honda Civic
Vindicator9000's Avatar
Yes. Everything is D-series except the bracket which should be B20.
On mine, I retained the entire D-series A/C system with the B20 bracket. The D series compressor should bolt up to the B20 bracket and everything will line up like OEM. This is because, if you've ever seen a CRV, it uses a D-series compressor on a B-series engine.
Originally Posted by Arcitekt View Post
here comes vindicator with his 30 line posts.
Vindicator9000 is offline   Reply With Quote
Old 12-14-2009, 06:31 AM   #11
GSR936
yes thats good. found a bracket and i got a donor 97 ek auto will all ac lines and stuff
Old 05-07-2010, 08:39 PM   #12
extremeEK00
hey where did u find that ac bracket from a b20?
extremeEK00 is offline   Reply With Quote
Old 05-07-2010, 08:41 PM   #13
extremeEK00
im thinking about putting a gsr swap into a 00 civic coupe and thought i needed the gsr ac bracket but read this and seen i need a b20 bracket?? is that true? how does that work?
96, 98, ac, back, bracket, civic, compressor, coupe, ek, gallery, gsr, honda, putting, series, swap, system, thread, whats
