H22 wont start?
H22 wont start?
So I've got a 94 civic hatch with a jdm H22a. and I dont drive it daily but start it several times a week. I premium (93 or 97 octane?) gas. Never had any type of issue with the car. I parked it and today I try to start it but it wont. The battery is fine, its gettin fuel, and its cranks but just wont start. after a while I smell fuel too, but theres no leaks or anything. I havent checked the spark plugs yet, but any ideas guys? its 40 degrees here so i know it isnt that cold.
Re: H22 wont start?
ok man first check if your geting spark to cylinder #1 if not you no it could be two things 1 your ignition coil is no good 2 your igntion control mod is no good easy to find out just take a volt meter and check for resistance dont no how look and chiltons manuel it will show you points to check also if they is a autozone near by they can also help
Re: H22 wont start?
I asked some people on honda swap too, they think its either the ICM or the coil. thanks for the first response, ill check it out and then let you guys know.
bsquared135
04-13-2009 11:37 AM
peter17212
10
02-08-2008 04:48 PM
