PCV valve, need some advice...
Old 12-10-2009, 09:18 AM
Alex M.'s Avatar
Default PCV valve, need some advice...
Ok, so I've been slowly trying to get this stock 90' GS that I bought from my nephew 3 weeks ago up and running. It had a brand new head installed on it before he sold it to me. Anyways, it's been smoking at higher RPM's, and after doing a search, I decided to focus my attention on the PCV valve. Well last night, after removing the PCV valve, I noticed the tube was broken where it goes into the breather canister. Now, the only way it seems to be accesible (comfortably) is by removing the intake, but I could be wrong. Now, I've read a ton of threads about catch cans and such, but nothing about replacing the breather canister. Is there a "simpler" way to fix this issue? It's like -25 degrees here in Chicago and I'd like to get this done quick. Thank you all in advance!
Alex
Old 12-10-2009, 10:08 AM
B18_kidd's Avatar
Default Re: PCV valve, need some advice...
You want that smoke at high RPMs it means u arent running lean. If you need a different PCV valve get one from like a semi or somethin that'll be a lot stronger and will have more suction.
Old 12-10-2009, 10:27 AM
chansta's Avatar
your pcv valve suction just depends on the pressure difference in your intake manifold and the pressure build up within the crankcase... you might be better off just buying a catch can cuz in the long run its better for your engines performance / life. if not... jus fix the broken tube no?
Old 12-10-2009, 10:47 AM
Alex M.'s Avatar
Well yeah I would like to replace the tube, but like I mentioned earlier, the tube is broken from the "black box" (breather canister) behind the block and it's REALLY hard to get anything in there. So, I am just wondering if there is an easy way to get to the canister so I could replace it. I don't think I wanna try going with a larger PCV just yet until I install the one I bought that is specific for this car.
Old 12-10-2009, 02:05 PM
Alex M.'s Avatar
Anyone else?
Old 12-10-2009, 03:09 PM
VPUPPY's Avatar
From the parts diagram, there is a breather joint (it's made of plastic) coming out of the chamber and the tube connects that joint to the PCV valve. Did the joint break off? Or is there still a little bit of tube sticking out?
Old 12-10-2009, 03:18 PM
Alex M.'s Avatar
No it broke off. Well, the actual tube broke off from the canister is what I mean. I can't reach the canister with my hands though, really tight
Old 12-10-2009, 03:39 PM
DriftMD's Avatar
Some pictures please.
Old 12-10-2009, 05:08 PM
Alex M.'s Avatar
Name:  PCV Valve and tube.jpg
Name:  PCV valve location.jpg
OK sorry for the shitty pics but all I have is my phone. The small hole under the intake is where the PCV tube goes.
Old 12-11-2009, 03:36 AM
Alex M.'s Avatar
Bump.....
Old 12-11-2009, 04:35 AM
Alex M.'s Avatar
Here's another pic to give you guys a better idea of what I'm talking about
Old 12-11-2009, 04:36 PM
Alex M.'s Avatar
Old 12-11-2009, 05:33 PM
VPUPPY's Avatar
The breather joint that the PCV valve tube attaches to has broken off. If you look at end of the tube that attaches to that end, you should see the remaining part of the joint. You may be able to pop the rest of the joint out of the canister with a screw driver. I believe the remaing part come out if you pull straight up.
Old 12-11-2009, 07:01 PM
Alex M.'s Avatar
Do I really need to connect that tube back into the canister?
Old 12-12-2009, 06:20 AM
Alex M.'s Avatar
Just wondering if I can run the PCV tube with the valve attached without having it connected to the canister for now...
Old 12-13-2009, 07:59 AM
Alex M.'s Avatar
Sorry guys, don't mean to be a pain in the ***, but could someone let me know if it's ok to just run the PCV valve, connected to the tube without hooking it back up to the canister? Thanks
Old 12-30-2009, 12:02 AM
DriftMD's Avatar
Yes you need to connect it back to how it was before. The PCV vents the crankcase and it is a part of the car's emission system.
eHMxhACk
03-23-2014 10:41 PM
jasoncrashtech
05-25-2013 08:10 PM
petrv
08-26-2005 02:26 PM
dr juice164
07-11-2004 10:04 AM
BpuTacoma
03-22-2002 10:00 PM
Quick Reply: PCV valve, need some advice...
