Old 12-09-2009, 05:50 PM   #1
butter99
butter99's Avatar
Send a message via AIM to butter99 Send a message via MSN to butter99
Default Is my Oxygen sensor bad?
93 H22a civic exhaust smells like fuel
I smogged my car and barely failed a few hydrocarbons over the limit. Then I had someone weld a cat on to my car with an electric welder. They grounded the unit to the exhaust. Next day I drove smoothly to the smog place and smogged it again. #43 (fuel system malfunction or bad O2) engine light came blinking and i failed horribly. CO 7% and hydrocarbons like 300. So I am dumping lots of fuel.
Do you think these symptoms are caused by a bad oxygen sensor? Whats the best way to test the sensor without replacing it?
butter99 is offline   Reply With Quote
Old 12-09-2009, 06:17 PM   #2
butter99
butter99's Avatar
Default Re: Is my Oxygen sensor bad?
bump
Old 12-09-2009, 06:29 PM   #3
Duc_du
Duc_du's Avatar
check youtube i believe there is a way to test the sensor because i saw it not too long ago. i think u need some kind of device though to read it.
Duc_du is offline   Reply With Quote
Old 12-09-2009, 06:48 PM   #4
butter99
butter99's Avatar
OK I'll check it out..thx
02, 2000, bad, caused, civic, honda, hondatech, integra, o2, oxygen, sensor, sensors, signs, symptoms, tech
