Old 12-05-2009, 10:46 PM   #1
RogueStatusVT3C
RogueStatusVT3C's Avatar
Send a message via AIM to RogueStatusVT3C
Default Wrong transmission fluid ends up stalling an automatic?
Hey guys, I have a serious problem on my hands.
So I was driving my car two days ago with some Castrol Import Transmission
Fluid in the car:
and ran fine. Acceleration and shifting was perfect.
Now I drive my car today only to find out that my mom's boyfriend adds
Castrol Domestic Transmission Fliud in the car:
I really thought nothing of it until I was driving. I accelerated slightly and around 20mph it stops accelerating. I had to turn off my car and turn it back on and slowly press on the gas just for it to move. I ended up having to pull over on the side of the road to turn off my car and turn it back on several times before I got home.
Does anybody know what was the problem? Could it have been the change in transmission fluid?
"Kick the VTEC, and S&!t starts getting crazy"
1995 2dr. Honda Civic EX
RogueStatusVT3C is offline   Reply With Quote
Old 12-06-2009, 12:30 AM   #2
thumper64
thumper64's Avatar
Default Re: Wrong transmission fluid ends up stalling an automatic?
Yes, the change in fluid can make an auto not work. You should drain it and refill a couple times.
Your mom's boyfriend is a complete moron, go beat him upside the head with a valve cover. He should never be allowed to touch your car, or another Honda again.
Scammer: egGO400 / Nick Pearl/decaneo (only lying thieves need aliases), Civicbackwards / Josh Hunt.
thumper64 is offline   Reply With Quote
Old 12-06-2009, 12:35 AM   #3
Linked
1994 Honda Civic
Linked's Avatar
linkedscorpion
make him pay for the fluid to change it out
2010 cadillac cts-v / 556 bhp / $62,020
only an idiot would buy a $62,000 cadillac
Originally Posted by 92lxsleeper View Post
it takes an even bigger idiot to put the $62,000 price tag on it
Linked is offline   Reply With Quote
Old 12-06-2009, 05:57 AM   #4
supra-n-civic
supra-n-civic's Avatar
Send a message via AIM to supra-n-civic
i hate it when douche bag non relatives try to molest yoru car, and for that matter your private business. tell him to quit trying to **** your mother or youll cut his shylocke nose off.
supra-n-civic is offline   Reply With Quote
Old 12-06-2009, 07:28 AM   #5
Pothole987
Pothole987's Avatar
the best stuff to use it honda automatic transfluid for these. lol get draining.
My Rides
2005 Honda Civic SE 2 DR, 2001 Acura EL 5 spd
2011 Chevorlet Silverado Cheyenne Edition 4WD
Pothole987 is offline   Reply With Quote
Old 12-06-2009, 11:23 AM   #6
RogueStatusVT3C
Thanks for all the help guys, and yes I'll make sure i'll beat him with a toaster. ^_^
Old 12-06-2009, 11:26 AM   #7
RogueStatusVT3C
Do you think that if I drain out the fluid and put in the right one, do you think there will be more than enough correct fluid (about 3 qts.) to thin out the "wrong" one?
Old 12-06-2009, 11:40 AM   #8
The_Honda_Guy
The_Honda_Guy's Avatar
Send a message via MSN to The_Honda_Guy
Most likely you'll need to drain and fill it a few times to try and thin out the bad stuff. Also, I'd highly recommend swapping to Honda ATF. It's only like 5 dollars a quart and is the CORRECT trans fluid for the car.
"A pedestrian is someone who thought there were a couple of gallons left in the tank." ~ Author Unknown
- Cody T.
The_Honda_Guy is offline   Reply With Quote
Old 12-06-2009, 12:39 PM   #9
Vindicator9000
318 Curves, 11 miles
2000 Honda Civic
Vindicator9000's Avatar
Yes, definitely. In my experience, Honda automatics are SUPER sensitive to transmission fluid. My CRV doesn't shift right with anything but official Honda ATF, and my old Accord didn't seem quite right without it either. I can fully see the wrong ATF causing weird problems for you because I've seen it myself.
Also: did he add because it was low, or did he add just for the hell of it? I've also found out the hard way that my auto Hondas seriously didn't like being overfilled - it caused very hard shifting. I'd imagine that underfilled might cause odd problems as well.
I would highly recommend doing a drain and fill with Honda ATF. If it still doesn't run right, I'd recommend trying a multiple drain and fill. Don't do a power flush on Honda automatics.
Originally Posted by Arcitekt View Post
here comes vindicator with his 30 line posts.
Vindicator9000 is offline   Reply With Quote
Old 12-06-2009, 06:05 PM   #10
supersize
supersize's Avatar
Send a message via AIM to supersize
drain and refill 3 or 4 times!
REJECT☆SQUAD #86 | Stay Fresh Crew |
Originally Posted by riot_05 View Post
i wish i would have known revenge made it easier.. cuz i havent cried once and i am not even sad about it. i should have started throwin stuff out windows years ago hahaha
supersize is offline   Reply With Quote
Old 12-06-2009, 08:39 PM   #11
RogueStatusVT3C
UPDATE:
Yeah, really pissed off now. Now I figure out that either I do it myself with my money or take it to a shop to get it fixed. Both which are above $50 minimum to do correctly, since you guys recommended flushing it out a couple of times.
Old 12-06-2009, 08:50 PM   #12
thumper64
thumper64's Avatar
Like we said, make him pay. He screwed it up, he should have to fix it.
Bring it to Honda, tell them what happened, charge the moron whatever they want to charge you.
Also, the toaster idea isn't bad. haha.
91, atf, castrol, change, civic, fluid, honda, import, oil, problems, reviews, stalling, trans, transmission, wrong
