Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 12-04-2009, 03:33 PM   #1
jsaye2002
Default New battery, good starter and alternator, but car won't start
I have a 90 CRX and just did a tranny swap. My battery was dead after so I bought a new one, hooked it up and it won't start. It sounds like it wants to but just wont. I checked all the grounds and everything and those are all fine. What could the issue be? Its starting to get on my last nerves!
jsaye2002 is offline   Reply With Quote
Old 12-04-2009, 03:44 PM   #2
4drEF
4drEF's Avatar
Default Re: New battery, good starter and alternator, but car won't start
Are you getting spark?
All of my posts should be considered for being made into a sticky.
4drEF is online now   Reply With Quote
Old 12-04-2009, 03:48 PM   #3
jsaye2002
i can't tell
Old 12-04-2009, 04:01 PM   #4
OneBadTurboCRV
OneBadTurboCRV's Avatar
Originally Posted by jsaye2002 View Post
i can't tell
LOL...
Well check it then...
'98 CRV EX
'13 Civic Si
OneBadTurboCRV is offline   Reply With Quote
Old 12-04-2009, 04:06 PM   #5
jsaye2002
yeah i'm waiting for my friend to get over here so I can. But I don't see why I would just stop getting spark after a couple days of the car sitting. It was working fine before. But I'll check and see whats up
Old 12-04-2009, 04:26 PM   #6
W O T TWO
Well obviously you have a problem, its not like the car "just sat" for a couple days, you did tranny service.
W O T TWO is offline   Reply With Quote
Old 12-04-2009, 04:47 PM   #7
jsaye2002
well i'm aware but it started perfectly before. and the tranny is more of a mechanical thing as oppose to an electrical. everything that was unplugged to do the work is back on. Thats why I'm confused as to why it isn't starting even with a new battery. but if my laggin *** friend would get here i could check the plugs
Old 12-04-2009, 04:50 PM   #8
Marcos Barrios
Marcos Barrios's Avatar
did you remember to connect the ground wire back on to your tranny?
Marcos Barrios is offline   Reply With Quote
Old 12-04-2009, 04:56 PM   #9
jsaye2002
the one that hooks to the battery under the rack thing? yes i got it. unless there is just something i'm forgetting. but i've hooked up the starter, ground under the rack, the motor one on the right side
Old 12-04-2009, 05:00 PM   #10
blasterman87
blasterman87's Avatar
whats it doing? is it cranking or just click click
blasterman87 is offline   Reply With Quote
Old 12-04-2009, 05:08 PM   #11
jsaye2002
its cranking. it was clicking but i put the ground on the starter better and it started cranking
Old 12-04-2009, 05:27 PM   #12
crx_si-r
crx_si-r's Avatar
carlos zapien c_zapien
Send a message via AIM to crx_si-r
the ground connects to 2 spots. the transmission and the frame itself. are both connected. also check your ignition switch. and main fuse
CJ's Tuck Harnesses
CRX LOG
Instagram c_zapien
crx_si-r is offline   Reply With Quote
Old 12-06-2009, 10:03 PM   #13
jsaye2002
As retarded as I feel asking this, where is the mount thats on the tranny itself?
Old 12-07-2009, 05:48 AM   #14
hatchet_honda
hatchet_honda's Avatar
Send a message via AIM to hatchet_honda
one on top and one on the front of the trans....did you unhook the ground wire on the thermostat housing? maybe to move the wire harness over a bit or somethin?
hatchet_honda is offline   Reply With Quote
Old 12-07-2009, 08:01 AM   #15
4drEF
4drEF's Avatar
Did you check for spark yet?
Old 12-07-2009, 12:45 PM   #16
jsaye2002
yeah i have spark. haven't been able to get to it the last couple days cuz I've been outta town. I really think there is just something I forgot to hook up. And and i don't remember hookin anything up to a tranny ground so I'm gonna go look for that
Old 12-07-2009, 01:10 PM   #17
4drEF
4drEF's Avatar
That ground goes from frame rail to the clutch cable bracket.
Old 12-07-2009, 01:15 PM   #18
jsaye2002
Old 12-07-2009, 01:18 PM   #19
ghg78
I NIKES
ghg78's Avatar
iTrader Rating: (1)
sounds like a ground unhooked.
ghg78 is offline   Reply With Quote
Old 12-07-2009, 01:50 PM   #20
4drEF
4drEF's Avatar
Odd that he's getting spark with a ground missing.
Figured you don't get spark or your starter doesn't crank when you miss a ground.
Old 12-07-2009, 02:50 PM   #21
ghg78
I NIKES
ghg78's Avatar
iTrader Rating: (1)
Seen it happen on a few accords when the ground that hooks to the thermostat housing gets left unbolted.
Old 12-07-2009, 03:51 PM   #22
jsaye2002
k everyone i got it....come to find out one of the wires hooked up to the dizzy wasn't all the way in lol. glad it was somethin simple
Old 12-07-2009, 04:13 PM   #23
csingham
crazy mad murdock
csingham's Avatar
Send a message via AIM to csingham
nice catch
Originally Posted by Kiwibird83 View Post
I should punch you right in your ***** mouth for asking that.
csingham is offline   Reply With Quote
Old 12-07-2009, 04:34 PM   #24
KINGVEM^^ED6
1991 Honda Civic
My Garage
KINGVEM^^ED6's Avatar
iTrader Rating: (1)
Glad u got it!
Originally Posted by tonylovesjdmEF9 View Post
i would choke my ex it was pretty fun and wild
KINGVEM^^ED6 is offline   Reply With Quote
2006, accord, alternator, battery, car, care, civic, clicks, good, honda, jumped, start, starter, unplugged, wont
