Daytime running lights, gauge cluster lights, and running brake lights>>not working
Old 12-01-2012, 02:14 PM
kingh90's Avatar
Default Daytime running lights, gauge cluster lights, and running brake lights>>not working
my daytime lights ( side markers....ect) and guage cluster lights, running tail lights are not functioning ( break lights work when break is applied). the lights were working all day until i purchased a Cobra Radar Detector. when i plugged it into the ac/dc port. everything was working fine... i went to the gas station to get gas, turned car off, got gas and when i started the car is when the problem erupted can anyone help. i just got done getting new fuses installed from pep boys. still not working...anyone ??
Old 12-01-2012, 02:34 PM
Swap'DShuttle's Avatar
Default Re: Daytime running lights, gauge cluster lights, and running brake lights>>not worki
Fuses pop when there is a fault in the circuit. Like a wire thats insulation has worn off and is grounding or shorting to metal for example. Find the fault, the fuse will stop blowing.
Old 12-01-2012, 04:25 PM
nemesis25's Avatar
Check for loose connector(s) going to the fuse box under the dash. More specifically, the one that goes from the light switch to the fuse box.
Old 12-01-2012, 05:15 PM
bigblue7t6's Avatar
I would also look into a faulty ground connection, maybe look into the wiring schematics and see if some of those circuits have a common ground
Old 12-01-2012, 05:50 PM
Also check if the fuse is blown again or not.
Jamie Martin
01-14-2013 07:17 AM
xkellyxveitx
11-07-2010 08:44 PM
jobe_149
02-11-2005 08:31 PM
SlowDC4
01-01-2005 06:59 AM
shaferz
02-29-2004 07:19 PM
Quick Reply: Daytime running lights, gauge cluster lights, and running brake lights>>not working
