01 accord power window fuse keep on blowing
Old 11-29-2009, 07:12 AM
lakerschamp2000's Avatar
Default 01 accord power window fuse keep on blowing
so i just bought this 01 accord coupe and the right window power abviously didn't work, so i check the fuse and it blew, then i replaced it and it blew right away as soon as i replaced it. what the heck is wrong with it? this car used to have sound system as i can see couple wires in the trunk....please help out asap. thanks
Old 11-29-2009, 01:49 PM
Default Re: 01 accord power window fuse keep on blowing
anyone with knowledge about fixing this problem, you are welcome to stop by my place and i will reward you with reasonable cash
Old 11-29-2009, 02:27 PM
redbull-1's Avatar
Well, a fuse blowing means a short; e.g., positive wire touching ground. You're going have to start checking the wiring for shorts.
Since you said this car use to have a sound system, I would suspect it may have to do with that. Start with the wires you see in the trunk, make sure they are not touching any ground. If that doesn't solve it, continue on to check the switch wiring on the right door and may even pull off the door panel and check the wiring, etc.
Old 11-29-2009, 03:47 PM
i did took out everything, door panel, checked motor, window regulator and also removed those sound system cables and fuse still keep blowing, maybe the meterplexer?
Old 11-29-2009, 04:27 PM
redbull-1's Avatar
Did you see any other wires that the previous owner connected to the fuse box to draw power from?
Even if there may be a problem with the multiplexer, it is still a short causing the fuse to blow.
Old 11-29-2009, 05:00 PM
not that i see any other wire running to the fuse box. already tried different motor and switch but still blowing fuse
Old 11-29-2009, 05:57 PM
craiger28's Avatar
There are wires under the dash on the drivers side that go to the power options on the door, i.e. window motors, window locks and they could be the problem. I have seen aftermarket alarms hooked up or torn out of these hondas that have this kind of issue.
Old 11-29-2009, 07:01 PM
there's no aftermarket alarm syst, oem honda security syst. thyanks
Old 12-02-2009, 05:59 PM
just got the car back and cost 380 bucks for the repair, damn that's alot. they replaced multiplexer and switch and took them almost 3 days to get it done. now all my interior lights are off and even the factory alarm syst does not work. wth
Old 12-02-2009, 06:23 PM
redbull-1's Avatar
They probably had a tough time finding the short and just replaced parts hoping it would take care of it. Sounds like some wires were not reconnected, as there may still be a short.
Old 12-02-2009, 09:42 PM
that's exactlly what i thought too, damn took it to a wrong shop
Old 01-11-2010, 08:41 AM
trackstar4302's Avatar
Have a 98 prelude and the ete fuse keeps blowing not allowing me to shift out of park. Haven't done anything to the car in years so not sure where to start. As soon as I change the fuse and shift it blows again. any ideas???
babykake91
03-30-2017 02:04 AM
Syke Fu
Honda Civic (2001 - 2005)
10-07-2011 10:41 AM
CB7=91
11-11-2009 11:44 AM
cadwiese
16
06-20-2008 11:38 PM
B-serious
06-05-2006 09:28 PM
Quick Reply: 01 accord power window fuse keep on blowing
