Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 11-23-2009, 06:18 PM   #1
DulinDragons
DulinDragons's Avatar
Default clutch will not engage or go into gear
I just finished my b18 swap and i cranked it up and it wont go into gear to move. None of them. So.... I went through the usual diagnosis. New clutch master, clutch slave, new clutch, new flywheel, and i bled the system down. I can see the slave working, so i do have hydrolic pressure.
I did bypass the neutral safety switch under the pedal with a push button start, but the switch is still plugged in. So idk if that can cause an issue
What can be the issue? Im able to shift into gears when the engine isnt running, but when the engine is running all i get is a grind. My guess is that the clutch isnt engaging. Please help
DulinDragons is offline   Reply With Quote
Old 11-23-2009, 07:02 PM   #2
fcm
Old Fart
fcm's Avatar
Default Re: clutch will not engage or go into gear
The clutch is not "disengaging", to confirm this, place in first gear and step on the clutch then turn ign. to start, [just for a sec.] if the car lurches forwards the clutch is not disengaging.
If car does not lurch forwards, clutch is disengaging and you have another problem, either shift linkage is misaligned, [unlikely if it will shift into gear when engine is not running, although still a possibility] or more likely it's bent shift forks or maybe blown synchromesh, [also unlikely if you can't put it into any gear]. 94
RIP Zack 2001-2013, my best friend.
fcm is offline   Reply With Quote
Old 03-15-2010, 06:56 PM   #3
Excel91CiViCsi
Excel91CiViCsi's Avatar
Send a message via AIM to Excel91CiViCsi
what kind of clutch are you using im having the same problem with my competition stage 2
00' EM1 -Sold!
95' EJ1 96+ ITR -Sold and totalled but NVRFGTN!
InnovativeMotorWorks
Excel91CiViCsi is offline   Reply With Quote
Old 03-14-2011, 09:23 AM   #4
eGJaKe22
Send a message via AIM to eGJaKe22
mines doing the same thing !!!!!!!!
eGJaKe22 is offline   Reply With Quote
Old 03-14-2011, 04:30 PM   #5
slowmoEM1
2000 Honda Civic
I have had the same problem,for me the fork assembly was not pushing the clutch in far enough to engage the clutch, I pulled my tranny off took off the fork, there is a nut that holds it on put two or three washers on the bolt then put the bolt back on the tranny, never had a problem with the clutch engaging after that. It was also a b18 swap with stage 2 clutch. Hope this helps.
slowmoEM1 is offline   Reply With Quote
Old 03-16-2011, 09:04 AM   #6
91 luder
91 luder's Avatar
pressure plate did u machine the flywheel ?
91 luder is offline   Reply With Quote
Old 04-15-2011, 09:34 PM   #7
paterson_DB!
Send a message via MSN to paterson_DB!
this is crazy iam having the same problem on two single cams . car turns on with out presing the clutch i can easyly put it into any gear and it wont do nothing at all .. Took the trany down put the new clutch in and still the same thing . Help help help please .. Adames123@msn.com
paterson_DB! is offline   Reply With Quote
Old 05-24-2011, 09:54 AM   #8
luis_ej8
iTrader Rating: (2)
I just got my civic with a b18c swap and its doing the same exact thing.has anybody found a solution?
luis_ej8 is offline   Reply With Quote
Old 05-24-2011, 11:10 AM   #9
UJLSMoFo
UJLSMoFo's Avatar
Location: east coast performance and tuning, jacksonville, nc
not that you dont know what your doing, but did you install the clutch disc in upside down.
93 honda hb sfwd 1008hp money bucket.
91 crx stock sleeve 10.64@134
UJLSMoFo is offline   Reply With Quote
Old 05-30-2011, 07:08 AM   #10
luis_ej8
iTrader Rating: (2)
El
Well I got my car running I had to replace my flywheel
Old 12-27-2011, 10:27 PM   #11
310GUERO
I have a problem with my manual transmission , it would work and angage fine for about 20 min if driving and then it would not engage at all till it coold down please help any idea why its doing this ??
310GUERO is offline   Reply With Quote
Old 02-05-2012, 05:52 PM   #12
lxdriver
2000 Honda Civic
vvfc_3_ej6
Old topic but I'm also having the same problem. I replaced the flywheel, clutch, and pressure plate (all brand new) and now my car wont go into ANY gear with the engine running, it does with it off. The slave cylinder works fine and I already bled the system. Any ideas why I cant get a gear??!?!?!
lxdriver is offline   Reply With Quote
Old 02-05-2012, 06:19 PM   #13
fcm
Old Fart
fcm's Avatar
Same as above, place in first gear, step on clutch and crank engine, if car lunges forwards, the clutch is not disengaging and that is why you can not get it into gear when engine is running.
Also, if the car lurches forward when in gear and you try and start it, it would indicate the clutch is working, [engauged].
You will need to look at the disingagement system, cable or hydro, to first make sure it is moving enough to disengauge the clutch, maybe all you need is an adjustment. 94
Old 03-19-2012, 04:02 PM   #14
Lozano1991
1992 Acura Integra
I have the same problem but I checked the flywheel clutch and pressure plate and they are all good.
Gears won't go in when car is on only off.
But I was thinking.. Could it be because I cleaned the clutch with wd40??????
Lozano1991 is offline   Reply With Quote
Old 03-19-2012, 04:52 PM   #15
fcm
Old Fart
fcm's Avatar
If you put it into gear and step on the clutch and then try and start it, does car lurch forwards? 94
Old 03-19-2012, 08:44 PM   #16
Lozano1991
1992 Acura Integra
If it does launch forward what does it mean?
And if it doesn't ?
Old 03-20-2012, 07:18 AM   #17
fcm
Old Fart
fcm's Avatar
If it does, the clutch works it is just not disengaging.
If it does not, clutch is not working, [engaging] properly.
Have you tried it? 94
Old 03-20-2012, 12:27 PM   #18
alex eg hatch
alex eg hatch's Avatar
iTrader Rating: (38)
Hondacivic512
El
Mine worked have replacing flywheel too!
Keep it JDM
MY EK HATCH!!
http://honda-tech.com/showthread.php?t=3042084
alex eg hatch is offline   Reply With Quote
Old 03-20-2012, 11:14 PM   #19
Lozano1991
1992 Acura Integra
I tried it and It moved forward in gear with the clutch in still.
So what could be the problem?
Old 03-21-2012, 04:33 AM   #20
fcm
Old Fart
fcm's Avatar
Clutch is not disengaging.
What is the MM&Y of your car?94
Old 03-21-2012, 01:25 PM   #21
Lozano1991
1992 Acura Integra
Mm&y?? Define please
Old 03-21-2012, 01:30 PM   #22
Lozano1991
1992 Acura Integra
I have a 92 integra with a b20b with a jdm ob2 ls tranny
Old 03-21-2012, 04:46 PM   #23
fcm
Old Fart
fcm's Avatar
Make model and year.
You have a G2 so is it still cable clutch or are you now hydro? 94
Old 03-21-2012, 11:21 PM   #24
Lozano1991
1992 Acura Integra
I went hydro.. Hush22 kit.
I found out what was my problem but I don't understand it.
If I push the clutch all the way.. Gears won't go in
But if I push it 3/4 in, gears go in
Do I need to adjust the pedal?
Old 03-22-2012, 06:21 AM   #25
fcm
Old Fart
fcm's Avatar
Something needs to be adjusted. 94
2000, accord, car, civic, clutch, disengaging, engage, engaging, engine, gear, gears, honda, running, s2000, shift
