Go Back   Honda-Tech > Honda and Acura Technical Forums > Wheel and Tire
Old 11-20-2009, 07:59 AM   #1
GoLowDrew
GoLowDrew's Avatar
Default Lug nut size
I did not see this in FAQ.
I've been using 19mm for a long time. With my 09 Odyssey, it's now 22mm.
As you know, tools are an investment.
Is is 22mm the new 19mm?
I think we can almost say 19mm to be the standard as I have used it on many other cars and etc without even giving it a second look.
If 22mm is not common, then I may hold of getting a few.
GoLowDrew is offline   Reply With Quote
Old 11-20-2009, 09:45 AM   #2
xunsungheroesx
xunsungheroesx's Avatar
Default Re: Lug nut size
Solution: buy a set with both. Not that expensive and you will have either on hand in case you get a new car, have to help a friend out, etc...
xunsungheroesx is offline   Reply With Quote
Old 11-20-2009, 10:02 AM   #3
GoLowDrew
GoLowDrew's Avatar
Correct, sockets are not that expensive. But I got breaker bars and a torque wrench. And unfortunately, it's 3/8 and not 1/2.
Old 11-20-2009, 10:31 AM   #4
xunsungheroesx
In that case then don't buy until you have an actual need for it. You can always carefully use a tire iron/cross if you get into a pinch. If you happen upon a good deal or a garage sale before that happens then you will have saved some cash and fulfilled your tool wants.
Old 11-20-2009, 11:15 AM   #5
nsxtasy
H-T Order of Merit
Doesn't your torque wrench use sockets?
nsxtasy is offline   Reply With Quote
Old 11-20-2009, 11:30 AM   #6
GoLowDrew
GoLowDrew's Avatar
My torque wrench is 3/8. The break bars are 1/2. Yes, I can buy two sockets ($20) = /thread.
I think I was just surprised to see Ody at 22mm. I thought I had "everything" when I went to rotate the tires. That was not the case.
Old 11-20-2009, 11:44 AM   #7
nsxtasy
H-T Order of Merit
Or you can buy one socket and one convertor from 3/8 to 1/2. As you said earlier, sockets are cheap.
I'm surprised they would change the size of the lug nut heads, though. Are the lugs the same diameter?
Old 11-20-2009, 11:59 AM   #8
GoLowDrew
GoLowDrew's Avatar
I don't know since I don't own an earlier model in this current gen. It was changed from 08+ to 22mm. We can find a reason that would fit, such as "new" transmssion-drivetrain to be more in line with the Pilot-Ridgeline.
Or just new wheel design.
05, 09, 2005, acura, civic, ep3, fit, honda, lug, lugs, nut, odyssey, size, thread, tl
