#1 | |||||
HX rims how too:http://www.honda-tech.com/showthread...highlight=rims coilovers how to:http://honda-tech.com/showthread.php?t=2682504 Last edited by 90_EX_Civic; 11-17-2009 at 06:06 PM. |
#2 |
i wouldnt recommend doing it this way, just do it right, my buddy went and picked up a spring compressor from his local auto shop for $50, did what needed to be done, then took it back, got his $50 bucks back. also you can just network, ask some buddies if they have one you can borrow, i wouldnt do it this way, just my 2 cents
#3 | |
the way it looks from the pics is different from what you might think. and i have tried using a spring compressor. didn't turn out well. one of the clamps slipped and the spring bowed out. lucky the other side held. that's when i was like fauck this and took it to a shop. looked at the car and cursed my self for half assing it and not taking everything that would bind or hold the shock/spring in. hence why i said unbolt the sway bar. that way your lower control arm can swing a full 90*. plus having the upper control arm unbolted helps. once you get the hang of this, it's shouldn't take more then 2 hrs, tops. also, this way if it were to shoot out, it would only hit the inside of your fender, and shoot ether straight up or down.
HX rims how too:http://www.honda-tech.com/showthread...highlight=rims coilovers how to:http://honda-tech.com/showthread.php?t=2682504 |
#4 |
the fact remains you can get the proper tool to do this and if used correctly will be safer and faster. The tool rental is free at most places if you leave a deposit so it isn't like this is a huge cost? but i guess if you cant get to the store this will work
#5 |
Good write up! I dont wanna steal your thread but, for me I left the car as is and did not jack it up. I just loosened up the 14mm nut w/ assistance from the allen wrench and then I proceeded to jack up the car and do the normal unbolting the lca from the knuckle and the fork from the strut etc.... and pretty much everything just fell out! nothing shot out or anything! it worked ok for me.
#6 |
Some notes:
- Autozone and places like that should be able to provide tool rentals... for free. - you disassembled way too many things: Front shocks 1. place car on jack stands 2. wheel wheels 3. unbolt brake lines from shock 4. remove 14mm pinch bolt from rear of shock. 5. remove 17mm shock fork bolt from control arm. 6. place jack under shock fork, put tension on suspension 7. pop hood, remove shock bolt. 8. slowly lower jack, spring and shock will separate. 9. remove 12mm bolts for shock hat. 10. remove shock fork from shock. remove shock and spring from car. done. 11. if you have a super super tall spring, separate ball joint between LCA and knuckle and remove sway bar. this will let the LCA drop. Rears are even easier.
"Straights are for fast cars. Turns are for fast drivers." RIP Homer... My '90 Honda CRX HF Uh Oh... |
#7 |
seems like a real ass backward way of doing things if you want my opinion.
a whole lot of work when a spring compressor is available free. id rather have the spring shoot into a wall than do all this work, to be honest.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there. FS: Mugen CF-48 13x5.5 -38 Wheels *NIB* FS: 4040 Brake Proportioning Valves |
#8 | |
otherwise, your method works just fine with any lowering spring.
#9 |
whats a spring compressor i have never used one to put lowering springs on any of my hondas
#10 | ||
the method you did i have tried before. only thing is that it's a pain in the ass to move the spring around the uca. that's why i remove it. same with the sway bar. also with the uca out of the way you don't have to remove the lca. its easier to move the shock/spring around. another note, you guys don't have to do it this way. i my self just find it easier this way. some may find my method reasonable some might not. it's just something to put on the table for people to see and if they like it, they can try it.
#11 | |
brave man.
#12 |
Ass backward method #2
Take off the strut/spring assembly together, lay it flat on the floor with your foot on the spring and impact the top nut off. Shock "shoots" out less than a foot & your done it less than 20 seconds.
ED6, dd (sold)
#13 | |
This and the OP's methods do work but are inherently unsafe and not recommended by any professional. Typically the people who try these methods are less experienced which makes these scenarios even more volatile. No one wants the business end of a quickly decompressing spring. Suspension work, no matter which method you choose, should be treated with caution and safety in mind. |
#14 |
#15 | |
only way ive ever done it haha. op, you did that shit the hard way. but congrats on at least doing it. Ive got over 20 suspension installs under my belt, 5 being just my own. Shit ive done it just this past week 2 times, and the wheels were still on! but i remember my first time ever, that shit took forever. I usually just undo the 14mm holding the fork and shock, undo the 17mm long bolt and pop it out with a screw driver, slide the fork off the shock and off the LCA, then undo the brake line if its bolted on, then undo the top 2 bolts and walla shock is removed. install is the same. dont have to **** with ball joints or any of the arms, and usually the swaybars are no big deal.
I <3 my Honda 95 coupe - sold 89 hatch - current |
#16 | |
One tweak though - I loosen the nut in the car and then use a manual wrench and not an impact when I'm standing on it. I also face the nut towards the garage door so when it does shoot off it's easy to find.
<--- wonders how SH!FT got a special tag under their user name? |
#17 | |
jeez my first time took forever too. but i can do it now in about 2hrs for all corners. i also didn't need to remove the fork cause i was reusing them. would have been different if i wasn't. i guess i should have added that i don't have a air compressor and no garage. just a gravel drive way that i do my work on, and it's safer then one might think. true it's technically not safe or professional, but i my self make sure i try to be as safe as i can when doing something like this.
#18 | |
Panda 89 Toyota Supra - Sold =[ Gold 88 Civic LX - DD - Project hElla Fresh |
#19 |
it shouldnt take you 2 hrs...
#20 |
I just cover the comlete shock assemble (on floor) with a heavy welding blanket and hit the Nut on the shock hat with the Impact. Easy as Pie and been done since my first civic in 95.
On Honda Civics there is not an insane amount of spring tension. But I guess an Idiot can get hurt
| Bookmarks |
| Tags |
| acura, coil, coilover, compressor, diy, overs, put, rsx, shock, sleeves, spring, springs, stock, tool, welding |
