Old 11-12-2009, 09:25 AM   #1
38genesis
Default seat height ???
i have 2000 ek coupe and i want to make my seat couple inches lower. can i cut anything just to make it happen? its a stock ek seats.
38genesis is offline   Reply With Quote
Old 11-12-2009, 09:30 AM   #2
b16binside
b16binside's Avatar
Default Re: seat height ???
aftermarket rails?
1996 B16B swapped honda civic
-WORK-WEKSOS-APEXI-JDM SHIT YO-MEGAN RACING-TEIN-SKUNK2-WEAPONR-HKS-ARIAS-EAGLE-TODA-
b16binside is offline   Reply With Quote
Old 11-12-2009, 09:47 AM   #3
38genesis
which rails can you think of? how much will it lower my seat down? will it be direct bolt-on on my stock seat
Old 11-12-2009, 09:59 AM   #4
b16binside
b16binside's Avatar
actually you know id try teg rails before spending bookoo bucks on a set of aftermarket rails
because i swapped a set of gsr seats into my EK and you can tell the height difference from the stock seats LS seats fit too if gsr isnt your thing
read this thread i think it may help you some
http://www.honda-tech.com/showthread.php?t=2618798
Old 11-12-2009, 10:09 AM   #5
38genesis
anything would be fine as long as they drop couple inches down its coz its hard for me to bend everytime i switch gears.
Old 11-12-2009, 10:15 AM   #6
Deetz
2000 Honda Civic
My Garage
Deetz's Avatar
I swapped the oem seats from my 2000 couple in favor of 2000 Integra seats...better in "every" way, which also includes sitting down a couple inches lower.
Look around, you should be able to find a pair for $100
Deetz is online now   Reply With Quote
Old 11-12-2009, 10:58 AM   #7
38genesis
cool thanks guys
Old 11-12-2009, 02:22 PM   #8
jdmcivicracer89
jdmcivicracer89's Avatar
yea like everyone says integra seats are alot lower. i got the ITR seats in my Em1 and its a pretty big noticable drop in height
00 Si Totaled R.I.P
06 speed6 -current Daily
92 cx hatch - Track whip
jdmcivicracer89 is offline   Reply With Quote
Old 11-12-2009, 11:28 PM   #9
38genesis
i found a pair. do i have to switch the railings and sliders or direct bolt on to ek
Old 11-13-2009, 07:21 AM   #10
b16binside
b16binside's Avatar
yeah they bolt right in
Old 11-13-2009, 01:28 PM   #11
Meoshe
2007 Nissan Titan
Meoshe's Avatar
Send a message via AIM to Meoshe
No you have to switch the inside rail from your seats the integra ones for them to fully bolt in. I would advise this so all 4 bolts can be used.
Meoshe is offline   Reply With Quote
Old 11-13-2009, 01:33 PM   #12
D Griff
D Griff's Avatar
on my DX the passenger side inside rail wouldn't work with the integra seats really because the tilt mechanism was kind of different, so I only have 3 bolts on the passenger side, but the EX may have the better tilt things like on the Integra seats
D Griff is offline   Reply With Quote
Old 11-13-2009, 02:38 PM   #13
supermansdx
i swapped in 94 prelude si seats into my ek and its significantly lower and extremely comfortable, its not quite as bolt and go as teg seats but requires very little modification and you wont have teg seats like everyone else.
supermansdx is offline   Reply With Quote
Old 11-13-2009, 05:45 PM   #14
vtectouge
vtectouge's Avatar
Send a message via Yahoo to vtectouge
can anybody tell me what kind of seats is this??
vtectouge is offline   Reply With Quote
Old 11-13-2009, 05:49 PM   #15
Deetz
2000 Honda Civic
My Garage
Deetz's Avatar
Sweet! It is required you switch only one rail on each seat, can recall now if it was the inner or the outer, but it will be very obvious
To those who think they bolt right in...NO, that is only for EG models!
Old 11-13-2009, 05:50 PM   #16
Deetz
2000 Honda Civic
My Garage
Deetz's Avatar
Those look like regular old stock ek seats, nothing special
Old 11-13-2009, 06:44 PM   #17
vndsd1
s2k seat, it sits very low
vndsd1 is offline   Reply With Quote
Old 11-13-2009, 07:53 PM   #18
vtectouge
vtectouge's Avatar
this seats are very up high in the sky i feel like a camel in car still waiting for my recaros seats havent arrive
Old 11-13-2009, 08:18 PM   #19
NOFX
H-T White Ops
NOFX's Avatar
del Sol seats sit low. Very surprised no one mentioned them.
They're noticeably lower than the Integra seats. I've had a '97 Civic here with both.
I AM NOT YOUR FRIEND (unless I am). DO NOT PM ME. _
If you make a thread then (1) more people will be able to answer and (2) the information can help others!
NOFX is offline   Reply With Quote
Old 11-14-2009, 04:01 AM   #20
supermansdx
the problem with del sol and s2k seats is since they come from two seater cars the reclining is very limited.
Old 11-14-2009, 09:17 AM   #21
NOFX
H-T White Ops
NOFX's Avatar
At least for the del Sol the reclining and folding forward was only slightly limited compared to the stock seats. They worked fine and I was still able to get in the back seat of the hatch. If it were a sedan it wouldn't matter if they folded forward. Plus on the S2000 I've heard of people doing seat pan swaps.
If you're tall enough to be uncomfortable in the car and you don't often have people crawling into the backseat then it won't be a problem at all. It will be a blessing. You don't usually have to worry too much about busing adults or adult sized people around in your car once you get out of high school, so dependent on the OP's age this could be a slight problem or not really a problem at all. After all, it's his car and he should be most comfortable in it since he's always driving it.
Old 11-15-2009, 04:33 PM   #22
vtectouge
vtectouge's Avatar
ITR seats is the read recaros right guys??
civic, del, height, honda, hondatech, integra, low, lower, oem, s2k, seat, seats, sit, sol, st
