Honda Accord 1992 Lighter socket fuse
Does anyone know which fuse in the ebox is connected to the lighter socket? I am trying to find a fuse that is off when the key is in the off position and on when the key is in the ACC or ON position. I know the lighter socket turns off with the key position. Thanks.
Re: Honda Accord 1992 Lighter socket fuse
I am also trying to find a fuse that is off when the key is in the off position and on when the key is in the ACC or ON position.Mr or Ms.userix.if u get the solution.suggest me
It's the number 11 fuse (10A) in the under dash fuse box. Note: When you look at your fuse box, it may not be in the same direction as this diagram and you won't usually see your relays until you remove the kick panel. But, you are only accessing the fuses, so all you need to do is remove the plastic door.
Frost7177
07-06-2007 03:44 PM
