> Honda Accord (1990 - 2002)
Old 11-06-2009, 09:17 PM   #1
Major90
Default 1994 Honda Accord not hitting VTEC
Hello,
Heres the problem:
I have a 1994 honda accord that i bought, the guy before me swapped the stock dx engine with the f22b1 vtec engine. The vtec was wired into the ecu harness, and i got a chipped p28 ecu, fixed the speed sensor, but im still being rev limited to 3500rpm. I noticed that the car has a f22b2 external coil on there, and if im not mistaking is the f22b2 non vtec distributer? could the distributer be the problem? If i were to purchase a f22b1 accord ex distributer would the looser wirings effect ecu readings? Thanks for the help.
Major90 is offline Report Post   Reply With Quote
Old 11-07-2009, 12:37 AM   #2
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Default Re: 1994 Honda Accord not hitting VTEC
That may fix it too since there's a blue wire inside the distributor which is the RPM wire. So try the B1 dizzy and see if it'll fix your problem. F22B1's are internal; not external like the B2.
1994 Honda Accord EX
- JDM H22A: Wrinkle Red Valve Cover; NGK Plugs; SS Header; AEM SRI; Exedy Stage 1 Clutch; Fidanza 8lbs Flywheel; Apexi WS2 muffler; & 2.5" custom piping.
nus_dogg is offline Report Post   Reply With Quote
Old 11-07-2009, 11:06 PM   #3
civic91sief
did he tell you anything about it having 2 step, the rev limiter of 35000 sounds like a 2 stage, which you can adjust to where you want to launch, you should look into that
civic91sief is offline Report Post   Reply With Quote
Bookmarks
94, accord, fix, vtec
