> Honda CRX / EF Civic
Old 11-06-2009, 08:24 PM   #1
akaspick
Icon6 Replacing the external door handle on a 90 Civic LX
Hi folks,
The external door handle on my 90 civic LX has cracked (can't open the door from the outside now) and I have bought a replacement from a local wreckers, but really have no idea how to go about putting the new one in.
I took a look at things and removed some screws from the inside panel. How many screws should I be looking for to take out from the inside?
After the screws are out, what would I be looking to do next? Since this is an LX, there is no crank for the window since it's all power locks, window, etc.
Any help is appreciated. Thanks.
akaspick is offline Report Post   Reply With Quote
Old 11-07-2009, 05:23 AM   #2
N3va3vaSatisfi3d
N3va3vaSatisfi3d's Avatar
Default Re: Replacing the external door handle on a 90 Civic LX
Yikes... If you don't know how to get a door panel off this is probably a little too much for you. This is very easy to do...
1.) Take off door panel.
2.) Pop off the rod linkage for the latch and lock.
3.) Take off the two nuts.
4.) Pull out the handle.
Originally Posted by N3va3vaSatisfi3d View Post
I PWN Information.
N3va3vaSatisfi3d is offline Report Post   Reply With Quote
Old 11-07-2009, 11:46 AM   #3
akaspick
Oh, I'm sure I can do this, but I just want to make sure I don't break anything doing something stupid. I'll go slow with the door panel. If things don't seem like they want to come off, I'll stop and assume I've missed a step and reevaluate the situation.
Old 11-07-2009, 12:50 PM   #4
N3va3vaSatisfi3d
Well then what are you waiting for? Stop wasting time on the Internet and get to it son!
I PWN Information.
Old 11-07-2009, 01:32 PM   #5
akaspick
Panel is off. 5 screws removed and then just pulling the panel off slowly to unlatch from the plastic "fasteners".
Next up... step 2.
Old 11-07-2009, 07:36 PM   #6
akaspick
I've done step 3, but am having problems with step 2.
How do I get the lock out of the old handle? It seems to be stuck in there pretty solid. Do I have to "punch" it out somehow? Also how do I unhook the rod going to the external handle? The space is pretty confined in there and I can't see how it's connected.
I just don't want to force something the wrong way possibly making things worse.
Thanks in advance.
Old 11-07-2009, 08:09 PM   #7
crx_si-r
crx_si-r's Avatar
Send a message via AIM to crx_si-r
you dont have to pop the rod off. if you notice on the door handle there is a rod with a type of bolt that connects the rod to the door handle. carefully twist and turn the door handle like your taking off a bolt. but first remove the 2 10mm bolts. then just re-install the new handle in reverse order.
crx_si-r is offline Report Post   Reply With Quote
Old 11-07-2009, 08:12 PM   #8
crx_si-r
crx_si-r's Avatar
i swapped out my key'ed door handle with a keyless one from a sedan...
Old 11-07-2009, 08:29 PM   #9
akaspick
I found some info here which has some information on the lock part and the rod in the picture in that thread looks like mine, although what it connects to is completely different. The setup in the picture looks a lot more spacious than mine.
I guess there are some clips I can't see holding the lock in.
I can't really see what connections the rod has from the angle I have, but I'll look again to see what I might be able to twist around. I can't even really get my hand in there, so this should be fun.
I'll try this again tomorrow and see where I end up.
Old 11-07-2009, 08:42 PM   #10
crx_si-r
crx_si-r's Avatar
there is a small horse shoe looking clip. just pry it off with a flat head. then the handle will come off after you twist it off.
Old 11-07-2009, 08:43 PM   #11
~sp33~
~sp33~'s Avatar
Send a message via AIM to ~sp33~ Send a message via MSN to ~sp33~
I took all the rods out with mine.
These things were such a PITA btw.
My 4wd EF 4 door
~sp33~ is offline Report Post   Reply With Quote
Old 11-07-2009, 09:59 PM   #12
crx_si-r
crx_si-r's Avatar
really? mine was out in less than 10 seconds. maybe its cuz i have a crx and not a sedan? j/k i didnt want to brake anything in case i decide to re-install the key door handles. i felt like removing it as a single unit would brake.
Old 11-07-2009, 10:19 PM   #13
akaspick
Once you had it off, how difficult was it to put back on? Seems like it could be a PITA for sure.
Old 11-07-2009, 10:36 PM   #14
crx_si-r
crx_si-r's Avatar
pair of pliers and the sucker is back on in seconds
Old 11-08-2009, 12:00 AM   #15
~sp33~
~sp33~'s Avatar
I was painting my car at the time, so putting it back in and trying not to scuff the paint around where the handle sits was epic PITA.
The rear door handles on the sedan are really confined by the shape of the wheel arch, it's really quite difficult.
My 4wd EF 4 door
Old 11-08-2009, 01:21 PM   #16
akaspick
Fixed it all up. My "horseshoe clip" was pretty rusty, and it took some force to get it off, but it came off eventually although the shape of it after the fact didn't quite look the same.
I also noticed the auto wrecker gave me a handle with a busted spring (or maybe it broke after I tried it a few times since it was so rusty) so the handle doesn't reset itself, but at least I can open my door now. The side of the handle attached to the rod was cracked, which didn't allow the handle to pull the rod up before.
It didn't look like there was any easy way to put my old spring on the new handle as the part the spring is attached to seems "riveted" on. 2 steps forward, 1 back... c'est la vie.
Old 11-08-2009, 07:48 PM   #17
~sp33~
~sp33~'s Avatar
Try some wd40?
My 4wd EF 4 door
Old 11-08-2009, 07:59 PM   #18
akaspick
wd40 on which spot? The handle actually isn't all that bad without the spring pulling it back in. It kinda falls back most of the way anyway.
The horseshoe clip was a PITA to take off, but it was cake to put back on... I thought it was going to be hell getting it back on cause I couldn't see a thing; turns out putting that clip back on was the easiest part.
Bookmarks
90, civic, door, handle, honda, predlude, removing
