> Honda Civic (2001- 2005)
Old 11-06-2009, 10:49 AM   #1
bgyore
Icon2 Steering Vibration when braking at highway speeds
Hello
I have a 2002 Civic EX coupe with 93k miles. When I am apply the brakes while driving above 60mph I get strong vibration/shimmy in the steering wheel. I do not get a shimmy/vibration at high speeds when the brake is not applied.The tires have still have 80% life and I rotate them fairly regularly, the brakes rotors are original but were turned approx 20k miles ago when I changed the brake pads (replaced w/OEM). I commute 25 miles to work daily and think that it is probably warped rotors but would like your guys opinion. Thank you in advance.
bgyore is offline Report Post   Reply With Quote
Old 11-06-2009, 12:51 PM   #2
youngturbo
Default Re: Steering Vibration when braking at highway speeds
had the same problem 5 months ago, it was warped rotors. I bought some brembo blank rotors and the problem went away.
youngturbo is offline Report Post   Reply With Quote
Old 11-06-2009, 07:05 PM   #3
Valenzuela
Valenzuela's Avatar
Send a message via AIM to Valenzuela
all you have to do is take your rotors off and go to a place around town that will turn them for you. easy fix no need to buy new ones and waste more money. O'Reilly auto parts turns them near me. if that helps
Valenzuela is offline Report Post   Reply With Quote
Old 11-07-2009, 04:37 AM   #4
jermie_jrmz
turn the front rotors and put some new brake pads.
jermie_jrmz is offline Report Post   Reply With Quote
Old 11-08-2009, 09:01 AM   #5
Harlowe
Function>Fashion
Harlowe's Avatar
Send a message via AIM to Harlowe
buy new rotors
2001 Honda Civic LX - meow
1991 Honda Civic Si OBD1 D16z6T (unfinished project) - Sold
Harlowe is offline Report Post   Reply With Quote
Old 11-08-2009, 09:53 PM   #6
Spoon ES2
i agree to all rotors replace resurface whateva u wanna do wtill work
Spoon ES2 is offline Report Post   Reply With Quote
Old 11-09-2009, 06:39 AM   #7
b0yg0tskills
b0yg0tskills's Avatar
Send a message via AIM to b0yg0tskills
since your at it change your brake pads
b0yg0tskills is offline Report Post   Reply With Quote
Old 11-09-2009, 10:04 AM   #8
Spoon ES2
i agree to boygotskills yes u should do pad while ure in there
Old 11-10-2009, 09:22 AM   #9
bgyore
Thank you all. The rotors were turned about 20k miles ago and at that time I replaced the pads with new ones. While I expected this to eventually happen, I did not think it would happen so soon after changing the pads. I am going to check the wheel bearings and upgrade to brembo rotors w/new pads. I will post the results once this is done.
Old 11-12-2009, 10:32 AM   #10
BigVic4545
I had this problem once and the culprit was a bubble/bump on one of the tires. Check your tires for any bubbles or bumps.
BigVic4545 is offline Report Post   Reply With Quote
Bookmarks
accord, acura, braking, fit, high, highway, honda, odyssey, shimmy, speed, steering, tsx, vibrates, vibration, wheel
