> Honda CRX / EF Civic
Old 11-05-2009, 02:42 AM   #1
MGR
MGR's Avatar
Default batterty reloction problems
ok so i did my batt relcate today along with my passager side wire tuck... after iwas done everything was good started ran fine no problems about an hour later wouldnt start. my relocation was done with 2 gauge indust.. wire from starter to + termanal and a 8 gauge amp wire to the fuse box and stock ground was used. also relocted to the trunk. any ideas ???
MGR is offline Report Post   Reply With Quote
Old 11-05-2009, 05:20 AM   #2
N3va3vaSatisfi3d
N3va3vaSatisfi3d's Avatar
Default Re: batterty reloction problems
Yeah, your ground should be no longer than 3 ft and as short as possible.
Originally Posted by N3va3vaSatisfi3d View Post
I PWN Information.
N3va3vaSatisfi3d is offline Report Post   Reply With Quote
Old 11-05-2009, 06:24 AM   #3
slow88si
slow88si's Avatar
Check for a drain on the battery.
75 chevy laguna, 383 stroker (parked)
88 crx si, b16 (DD)
slow88si is offline Report Post   Reply With Quote
Old 11-05-2009, 12:10 PM   #4
MGR
MGR's Avatar
the stock grounding cable was used the 8 gauge was used for the power to the fuse box
Old 11-05-2009, 12:31 PM   #5
4drEF
4drEF's Avatar
Do your accessories in the car turn on?
I had a problem where I would lose ground completely.
Ended up trying a few different grounding points in the trunk until I found a good one. Old car... spot welds... not the greatest.
Spare tire bolt didn't work, bolt for rear seat didn't work - ended up using a bolt on the tail light.
I eventually a 4 gauge ground forward in the can and tapped into it a couple couple places (chassis under the dash, chassis under the hood, and and terminated on the tranny ground).
I ran three 4 gauge wires off my battery.
One went to the stereo amps in the trunk, two ran forward to a fused distribution block under the passenger seat (that split out to supply alarm, fuse box, etc), and one ran up to the starter.
Never had power issues after that. Headlights never dimmed... nothing.
. o 0 0_o 0 o .
4drEF is offline Report Post   Reply With Quote
Old 11-05-2009, 12:59 PM   #6
buds302
buds302's Avatar
where did you ground it at? you say the trunk... but to what? or to where in the trunk is it grounded? wherever it is grounded make sure it is tight... and all the paint at the point of contact is gone. if it just looks ok.... get a wire brush and do it again.. and be sure its tight.
buds302 is offline Report Post   Reply With Quote
Old 11-05-2009, 01:54 PM   #7
MGR
MGR's Avatar
its grounded to a bolt right under the tail lights.
Old 11-05-2009, 02:52 PM   #8
91-CRX-Si
91-CRX-Si's Avatar
You have a ground issue,look I put mine in the back to used 4 gauge power to the front and made my own ground point with four gauge wire ,make sure your metal to metal and make sure you engine has a good ground to.One more thing check your post on batt. make sure there tight. Good luck
I'm so JDM I sleep on the right side of the bed!
JDM Because Asian Hookers Don't Like Chevy's!
91-CRX-Si is offline Report Post   Reply With Quote
Old 11-05-2009, 02:55 PM   #9
Kao510
You might want to clean the surface of your ground to get better contact.
Kao510 is offline Report Post   Reply With Quote
Bookmarks
