> Honda CRX / EF Civic
Old 11-03-2009, 07:55 PM   #1
thegoatc
Default D16Z6 Swap help
Hi I have a 88 ef that i did a d16z6 swap on. The swap consisted of a y8 mani, obd1 dizzy and obd2 injectors. The car was dpfi before i started. I used this wiring diagram to convert the injectors and dizzy over. Then i used a friends prebuilt obd0 to obd1 harness (i wont say what brand name but it works great in his car) to convert crom obd1 to obd2. Now i have the car started and it runs great but... The engine light comes on. This is not like a normal engine light it turns on for about a 5 count then off for one count. It always does this and when the light cycles the car surges making it difficult to drive in town. I have double and tripple checked my harness and the only differnce between mine and my friends is i have my own wires for the injectors instead of them going throught the original harness.
Hoping someone else has had this problem and is willing to shed some light on the subject.
Eric
thegoatc is offline Report Post   Reply With Quote
Old 11-03-2009, 08:04 PM   #2
BiG ChOr!Zo
BiG ChOr!Zo's Avatar
Default Re: D16Z6 Swap help
87 civic tech questions belong in the forum link below...!!!
http://www.honda-tech.com/forumdisplay.php?f=106
BiG ChOr!Zo
BiG ChOr!Zo is offline Report Post   Reply With Quote
Old 11-04-2009, 09:14 AM   #3
thegoatc
Sorry it is a late 87 so it is still an ef 88 is the actual body style.
Eric
Old 11-04-2009, 02:12 PM   #4
N3va3vaSatisfi3d
N3va3vaSatisfi3d's Avatar
Originally Posted by thegoatc View Post
y8 mani, obd1 dizzy and obd2 injectors. obd0 to obd1 harness to convert crom obd1 to obd2.
Wait, you are OBD-1 or OBD-2 now (which ECU are you running)? Also, when you did the injector wiring where and what did you hook each one up to?
Originally Posted by N3va3vaSatisfi3d View Post
I PWN Information.
N3va3vaSatisfi3d is offline Report Post   Reply With Quote
Old 11-04-2009, 02:54 PM   #5
thegoatc
Now i am obd1 and i am running a p28 ecu and I am using the injector outputs on the ecu with a 12+ source going to the other side of the injectors.
eric
Old 11-04-2009, 03:18 PM   #6
4drEF
4drEF's Avatar
Just a guess... Map sensor?
And it seems that you have permanently jumped your ECU into diagnostic mode somehow.
OBD1 puts the codes out at the check engine light, but ONLY after you short two wires together... seems like yours might be shorted.
. o 0 0_o 0 o .
4drEF is offline Report Post   Reply With Quote
Old 11-05-2009, 02:09 AM   #7
thegoatc
no these two wires are not jumped togather i can jump them togather and from what i can tell it is sending a code 10 but if i check the resistance for the intake temp sensor it is in spec so really don't know what to do at this point.
Eric
Old 11-05-2009, 05:09 AM   #8
gnar kill
gnar kill's Avatar
I thought this as well but it blinks in 5 second intervals and changes when he jumps it to get the code. That is why he is thinking a code 10 IAT. It is not a normal CEL light I am confused as to why it is only blinking in 5 second intervals when it is not jumped. Does anyone have any input?
-Casey
gnar kill is offline Report Post   Reply With Quote
Old 11-05-2009, 10:50 AM   #9
gnar kill
gnar kill's Avatar
bump I am curious about this as well....I have read else where about a "no code" cell that acts similar to this and was solved by replacing the main relay. But the main relay was replaced with a brand new one and the ECU runs my obd1 crx z6 just fine with no codes.
Old 11-07-2009, 02:22 PM   #10
gnar kill
gnar kill's Avatar
TTT
Old 11-10-2009, 07:11 PM   #11
thegoatc
to the top to see if any one can help
Eric
Old 11-16-2009, 04:01 AM   #12
thegoatc
desprate try ti see if anyone has any input
Bookmarks
87, 90, accord, check, checking, civic, code, codes, convert, d16z6, ef, engine, light, obd0, obd1, obd2, swap
