> Honda CRX / EF Civic
Old 11-03-2009, 02:34 PM   #1
xxstuntin4life
xxstuntin4life's Avatar
Send a message via AIM to xxstuntin4life
Default after MPFI swap.. codes 4,8,9
Well i just finished a MPFI swap on a 89 dx crx.. i put in a jdm d15b vtec in it for a friend and i still have it running obdo (vtec isnt hooked up) but i wired the dizzy to obd1 because the motor came with a obd1 dizzy.. i thought maybe i switched up pin b10 and b12 at the ecu so i switch thos around and it seems like it runs worse now so i put them back to the way it was before..
i know these sensors are all in the dizzy but do u think the dizzy might of tookin a shit?
code-
4- crank angle
8-TDC
9- CYP
-93 purple dx coupe b16a3, 88 crx si built/boosted dohc zc, 07 r6 with bolt ons
~~~~ myspace.com/iheartboost06 add it!
JUMP OFF A BRIDGE JUAN! NOW!!
xxstuntin4life is offline Report Post   Reply With Quote
Old 11-03-2009, 02:41 PM   #2
4drEF
4drEF's Avatar
Default Re: after MPFI swap.. codes 4,8,9
You can't run the OBD1 dizzy with an OBD0 ECU.
. o 0 0_o 0 o .
4drEF is offline Report Post   Reply With Quote
Old 11-03-2009, 02:55 PM   #3
xxstuntin4life
y not? ive heard of people doing it before
Old 11-03-2009, 03:26 PM   #4
4drEF
4drEF's Avatar
Oh really?
And how many of them ran correctly?
The reluctor ring inside the distributor has a different number of teeth.
If you run the OBD-1 on your OBD-0 ECU then you get the wrong pulses to the ECU... and it will never run right.
. o 0 0_o 0 o .
Old 11-03-2009, 06:04 PM   #5
N3va3vaSatisfi3d
N3va3vaSatisfi3d's Avatar
Oh really?
Exactly...
Originally Posted by N3va3vaSatisfi3d View Post
I PWN Information.
N3va3vaSatisfi3d is offline Report Post   Reply With Quote
Old 11-03-2009, 09:46 PM   #6
xxstuntin4life
Oh really?
i called rywire and u are right my friend.. thanks.. it runs but just throws thos codes.. and when i mean runs, it barely runs lol
Old 11-03-2009, 09:47 PM   #7
xxstuntin4life
wat about running obd1 injectors just spliced in?
Old 11-04-2009, 01:56 PM   #8
N3va3vaSatisfi3d
Are you running a resistor box or no?
I PWN Information.
Old 11-04-2009, 02:10 PM   #9
xxstuntin4life
na.. i took the 5 wires that lead to the resistor box and put them all together
Old 11-04-2009, 02:14 PM   #10
N3va3vaSatisfi3d
Then yes, you can use OBD-1 injectors.
I PWN Information.
Old 11-04-2009, 02:24 PM   #11
munchies91crx
you should really just get you a obd0 to obd1 jumper. for the dizzy, and ecu. and bam! problem solved. wire in your vtec. and bam jdm d15b vtec running like a champ.
munchies91crx is offline Report Post   Reply With Quote
Old 11-05-2009, 01:13 AM   #12
xxstuntin4life
i would if it was my car trust me.. if u saw my cars u would see there crazy clean.. but this is my friends whip and he is on a big budget so hes tryin to cheap it out.. :/
Old 11-05-2009, 04:34 AM   #13
chandler
chandler's Avatar
half a**ed equals half fast, I just had to fix a harness for a guy that has all of the wires twisted together and heat shrinked, took me six hours to un cluster that charlie foxtrot.
chandler is offline Report Post   Reply With Quote
Bookmarks
distributor, honda, mpfi, obd0ecu, obd1, run, swap
